7i96s outputs closed when not activated, but loaded
- Streng123
17 Jun 2024 00:27 #303139
by Streng123
7i96s outputs closed when not activated, but loaded was created by Streng123
Im getting to hooking up my cut60 plasma cutter to the board. using output 00 + and -, the torch fires as soon as i plug the connector to the board. I checked the board side and have OL resistance between the 2 ports when closed and very little when commanded open. i even tried wiring in a relay to control the torch and the 5v relay turns on the same way.
Anyone have any insight on what this could be?
- Thank you received: 5334
17 Jun 2024 00:39 #303141
Replied by PCW on topic 7i96s outputs closed when not activated, but loaded
Remove this line:
setp hm2_7i96s.0.ssr.00.invert-00 true
Also you should never hot plug inductive loads
- Streng123
17 Jun 2024 01:06 #303142
by Streng123
Replied by Streng123 on topic 7i96s outputs closed when not activated, but loaded
Thanks! Ill give it a shot when in out at the shop.
Noted
Noted
- Streng123
23 Jun 2024 20:56 #303652
by Streng123
I had the polarity of the leads backwards. This was the initial issue, the invert would have been my next. Thanks for the help!
Time to create page: 0.500 seconds
