Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
22 Jun 2024 01:05 #303523 by electrosteam
My 3-axis mill operated for over a year with LC 2.8.4 on a RPi 4B 4GB.
Then I tried to get the WiFi working. failed the SD card, so started to install LC 2.9.2 with a new SD card.
Problems from the start resulted in me changing to a RPi 4B 8GB, propped up outside the cubicle.
Now, when pinging, I get serious packet loss.
All addresses etc correct as I have had Axis opening on occasion.
The original installed ethernet cable is 250 mm long, and I have a general-purpose spare 10 m long on a spool.
With either cable connected, either way around, finger stressing the connection at the 7i96 socket interrupts packets.
The same stressing at the RPi socket is reliable.
Sometimes, with a bit of stressing, the monitor LED on the 7i96 socket extinguishes.
Sometimes packets will start on the ping, but other times not, with a bit of stressing then starting the packets.
It would appear the Socket on the 7i96 is the problem.
Any suggestions ?
John.
22 Jun 2024 01:31 #303524 by PCW
You might try cleaning the 7I96 RJ45 socket in case it's contaminated/corroded.
Worst case, you can return it to Mesa for repair/replacement
22 Jun 2024 02:20 #303525 by electrosteam
PCW, thanks for that.
Gave the contacts a good wash with isopropyl alcohol and preliminary results seemed better, but stats show about 50 % lost packets.
I will try again tomorrow.
Regardless of solution, I need to purchase a replacement board, if only as a spare for future.
Are there any agents in Australia (I am in Sydney) ?
John.
  • Platinum Member
  • Platinum Member
22 Jun 2024 02:38 #303526 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
I've got the equipment & ability to do that sort of work, based in Sydney myself, used to work as a tech for one of the larger EFTPOS companies doing smd board level repairs. I could even just look at it for you you.
But fully understand if you want to go through Mesa.
23 Jun 2024 01:16 - 23 Jun 2024 02:06 #303582 by electrosteam
Tried a third cable this morning with similar results.
cornholio,
Thanks for the kind offer, I will send a PM.
John.
edit:
Well, PMs don't work.
How can we get in touch ?
John.
Last edit: 23 Jun 2024 02:06 by electrosteam. Reason: Getting in touch.
  • Platinum Member
  • Platinum Member
23 Jun 2024 02:21 #303588 by Cant do this anymore bye all
Contact details are on my gtihub page.
github.com/ozzyrob
23 Jun 2024 12:52 #303642 by kzali
I have a 7i96 brand new and unused, You are welcome to contact me in the Sydney area and Cornholio has my contact.
Cheers
Kamran
24 Jun 2024 00:07 #303655 by electrosteam
Kamran,
Thanks, I will take you up on your offer.
Powered up the system at 15 degrees C this morning and got for ping "not reachable".
Went through menu-config, changed nothing.
Then ping and got 86 packets through, frozen count, stats 45% lost.
Earthing looks good, card power is 5.07 V.
John.
24 Jun 2024 00:37 #303657 by kzali
Hi John my email is in my github profile, github.com/kzali, please contact me and I will be happy to work something out.
cheeers
Kamran Zali
  • Platinum Member
  • Platinum Member
24 Jun 2024 06:09 #303668 by Cant do this anymore bye all
Just out of interest if you disable the wifi netwotk via the network manager do you still notice this behaviour.
What are the subnets of the Mesa & Lan networks ?
Moderators: PCW, jmelson
Time to create page: 0.157 seconds
