Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
- electrosteam
- Thank you received: 8
22 Jun 2024 01:05 #303523
by electrosteam
Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B was created by electrosteam
My 3-axis mill operated for over a year with LC 2.8.4 on a RPi 4B 4GB.
Then I tried to get the WiFi working. failed the SD card, so started to install LC 2.9.2 with a new SD card.
Problems from the start resulted in me changing to a RPi 4B 8GB, propped up outside the cubicle.
Now, when pinging, I get serious packet loss.
All addresses etc correct as I have had Axis opening on occasion.
The original installed ethernet cable is 250 mm long, and I have a general-purpose spare 10 m long on a spool.
With either cable connected, either way around, finger stressing the connection at the 7i96 socket interrupts packets.
The same stressing at the RPi socket is reliable.
Sometimes, with a bit of stressing, the monitor LED on the 7i96 socket extinguishes.
Sometimes packets will start on the ping, but other times not, with a bit of stressing then starting the packets.
It would appear the Socket on the 7i96 is the problem.
Any suggestions ?
John.
Any suggestions ?
John.
- Thank you received: 5334
22 Jun 2024 01:31 #303524
Replied by PCW on topic Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
You might try cleaning the 7I96 RJ45 socket in case it's contaminated/corroded.
Worst case, you can return it to Mesa for repair/replacement
- electrosteam
22 Jun 2024 02:20 #303525
by electrosteam
Replied by electrosteam on topic Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
PCW, thanks for that.
Gave the contacts a good wash with isopropyl alcohol and preliminary results seemed better, but stats show about 50 % lost packets.
I will try again tomorrow.
Regardless of solution, I need to purchase a replacement board, if only as a spare for future.
Are there any agents in Australia (I am in Sydney) ?
John.
John.
- Thank you received: 426
22 Jun 2024 02:38 #303526
Replied by Cant do this anymore bye all on topic Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
I've got the equipment & ability to do that sort of work, based in Sydney myself, used to work as a tech for one of the larger EFTPOS companies doing smd board level repairs. I could even just look at it for you you.
But fully understand if you want to go through Mesa.
- electrosteam
23 Jun 2024 01:16 - 23 Jun 2024 02:06 #303582
by electrosteam
Tried a third cable this morning with similar results.
cornholio,
Thanks for the kind offer, I will send a PM.
John.
edit:
Well, PMs don't work.
How can we get in touch ?
John.
cornholio,
John.
edit:
John.
Last edit: 23 Jun 2024 02:06 by electrosteam. Reason: Getting in touch.
23 Jun 2024 02:21 #303588
Contact details are on my gtihub page.
github.com/ozzyrob
github.com/ozzyrob
- kzali
- Thank you received: 12
23 Jun 2024 12:52 #303642
by kzali
Replied by kzali on topic Mesa 7i96 Ethernet Socket Problems - LC2.9.2 on Raspberry Pi 4B
I have a 7i96 brand new and unused, You are welcome to contact me in the Sydney area and Cornholio has my contact.
Cheers
Kamran
Cheers
Kamran
- electrosteam
24 Jun 2024 00:07 #303655
by electrosteam
Kamran,
Thanks, I will take you up on your offer.
Powered up the system at 15 degrees C this morning and got for ping "not reachable".
Went through menu-config, changed nothing.
Then ping and got 86 packets through, frozen count, stats 45% lost.
Earthing looks good, card power is 5.07 V.
John.
John.
- kzali
24 Jun 2024 00:37 #303657
by kzali
Hi John my email is in my github profile, github.com/kzali, please contact me and I will be happy to work something out.
cheeers
Kamran Zali
cheeers
Kamran Zali
24 Jun 2024 06:09 #303668
Just out of interest if you disable the wifi netwotk via the network manager do you still notice this behaviour.
What are the subnets of the Mesa & Lan networks ?
