Help with 7i95T
- loogyboy
24 Jun 2024 03:28 - 24 Jun 2024 03:30 #303664
by loogyboy
Help with 7i95T was created by loogyboy
I have tried to configure the 7i95T with MESA CT with no success. I am on linuxcnc 2.92 and debian 12. The issue I am running into is parameter or pin 'hm2_7i95.0.dpll.01.timer-us' not found. if I comment this out, then the following line for step gen throws an error. If i comment that out after, then all step gen throws errors. any help would be appreciated.
Last edit: 24 Jun 2024 03:30 by loogyboy.
- Thank you received: 7490
24 Jun 2024 10:15 #303682
Replied by tommylight on topic Help with 7i95T
What error do you get after omitting the dpll line?
The attached report contains the dpll error.
- Thank you received: 5334
24 Jun 2024 19:15 #303711
Replied by PCW on topic Help with 7i95T
Weird...
Whats does
mesaflash --device 7i95t --addr 192.168.1.121 --readhmid
report?
Whats does
report?
- loogyboy
28 Jun 2024 18:52 #303987
by loogyboy
Replied by loogyboy on topic Help with 7i95T
Configuration Name: HOSTMOT2
BoardName : MESA7I95
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 29
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for Step/DIR+Serial+Encoders -> 7I95_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-2,3 0 IOPort None
TB3-4,5 1 IOPort None
TB3-8,9 2 IOPort None
TB3-10,11 3 IOPort None
TB3-14,15 4 IOPort None
TB3-16,17 5 IOPort None
TB3-20,21 6 IOPort None
TB3-22,23 7 IOPort None
TB4-2,3 8 IOPort None
TB4-4,5 9 IOPort None
TB4-8,9 10 IOPort None
TB4-10,11 11 IOPort None
TB2-14,15 12 IOPort None
TB4-16,17 13 IOPort None
Internal 14 IOPort None
TB4-20,21 15 IOPort None
TB4-22,23 16 IOPort None
Internal 17 IOPort None
TB1-1,2,9,10 18 IOPort None
TB1-4,5,12,13 19 IOPort None
TB1-7,8,15,16 20 IOPort None
TB1-17,18 TB2-1,2 21 IOPort None
TB1-20,21 TB2-4,5 22 IOPort None
TB1-23,24,TB2-7,8 23 IOPort None
TB2-9,10,17,18 24 IOPort None
TB2-11,12,20,21 25 IOPort None
TB2-15,16,23,24 26 IOPort None
Internal 27 IOPort None
Internal 28 IOPort None
IO Connections for I/O+Expansion -> 7I95_1
Internal 29 IOPort None
Internal 30 IOPort None
Internal 31 IOPort None
Internal 32 IOPort None
Internal 33 IOPort None
TB3-13,14 34 IOPort None
TB3-15,16 35 IOPort None
TB3-17,18 36 IOPort None
TB3-19,20 37 IOPort None
TB3-21,22 38 IOPort None
TB3-23,24 39 IOPort None
Internal 40 IOPort None
P1-01/DB25-01 41 IOPort None
P1-02/DB25-14 42 IOPort None
P1-03/DB25-02 43 IOPort None
P1-04/DB25-15 44 IOPort None
P1-05/DB25-03 45 IOPort None
P1-06/DB25-16 46 IOPort None
P1-07/DB25-04 47 IOPort None
P1-08/DB25-17 48 IOPort None
P1-09/DB25-05 49 IOPort None
P1-11/DB25-06 50 IOPort None
P1-13/DB25-07 51 IOPort None
P1-15/DB25-08 52 IOPort None
P1-17/DB25-09 53 IOPort None
P1-19/DB25-10 54 IOPort None
P1-21/DB25-11 55 IOPort None
P1-23/DB25-12 56 IOPort None
P1-25/DB25-13 57 IOPort None
FPGA Pins: 256
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
28 Jun 2024 18:57 - 28 Jun 2024 19:24 #303988
That looks like the fallback configuration
do you have a blinking red "INIT" LED?
How are jumpers W15 and W16 set?
Last edit: 28 Jun 2024 19:24 by PCW.
