7i96s Board Firmware
- Project_Hopeless
- Thank you received: 10
05 Jul 2024 20:23 #304494
by Project_Hopeless
7i96s Board Firmware was created by Project_Hopeless
Maybe a stupid question but, does a 7i96s board come pre-loaded with basic firmware? I don't recall loading firmware on my previous 7i96.
I have a basic Axis config with one rotary axis on Step-0.
I can identify the board with the Mesa CT utility, just can't drive my stepper motor, as if Pul and Dir signal are not being sent.
- Thank you received: 7485
05 Jul 2024 20:33 #304496
Replied by tommylight on topic 7i96s Board Firmware
Yes it does.
Use a DVM to measure the voltage at the drive inputs.
Are the stepper motors locked when powered on?
Is Enable wired to the drives? If yes, disconnect it till you get things working.
And do the tests with a finished configuration running LinuxCNC, not from wizards.
- Thank you received: 5328
05 Jul 2024 22:46 #304498
Replied by PCW on topic 7i96s Board Firmware
As usual, posting your hal and ini files will help to diagnose the issue.
- Project_Hopeless
05 Jul 2024 23:56 #304507
by Project_Hopeless
Replied by Project_Hopeless on topic 7i96s Board Firmware
Yes the coil is powered, rotor locked, enables are not connected at present. With these TB6600 putting power to the enable disabled the motor.
I'm just trying for the bare minimum at this point.
06 Jul 2024 00:12 - 06 Jul 2024 00:18 #304508
1. Make sure you wire the TB6600 in single ended mode:
7I96S GND --> TB6600 PUL-,DIR-
7I96S STEP+ --> TB6600 PUL+
7I96S DIR+ --> TB6600 DIR+
If you don't want to double any wires
(like GND in the above example) you can:
7I96S +5V --> TB6600 DIR+
7I96S DIR- --> TB6600 DIR-
2. The TB6600 has very slow inputs, it will not see a 2 usec
(2000 ns) step pulse. I would try 20 usec (20000 ns).
Last edit: 06 Jul 2024 00:18 by PCW.
The following user(s) said Thank You: Project_Hopeless
- Project_Hopeless
06 Jul 2024 00:32 #304509
by Project_Hopeless
Thanks I'll give all this a try, I'm not wired single ended at present.
- Project_Hopeless
06 Jul 2024 14:44 #304542
by Project_Hopeless
Your first example, 3 wires single ended would make the wiring cleaner.
I don't plan on using the enable so I would have only 4 wires running differential, not terrible. What is the benefit of single ended?
Yes step pulse ended up being the issue. I seem to recall this tripped me up once before.2. The TB6600 has very slow inputs, it will not see a 2 usec
06 Jul 2024 17:24 #304550
Differential is mainly useful for servo drives with line receiver inputs.
Optocoupler inputs do not really benefit from differential drive,
and the differential drive lowers the maximum output current.
(and inexpensive drives often require quite high drive currents)
Time to create page: 0.254 seconds
