"error finishing read" with Mesa 7i92T on fresh install
11 months 2 weeks ago #338354 by Jensner
I Installed the
r8168-dkms Package and till now the error hasn`t appeared again...
WIll have a look at it.
Best regards
Jens
11 months 2 weeks ago #338365 by Jensner
OK, after 2 hours of testing, the error appeares again...
Someone who can help me..
Best regards
Jens
11 months 2 weeks ago #338367 by tommylight
If you do not need the latest features, you would probably be much better off by using the 2.8.4 ISO of LinuxCNC, and it is very easy to test if that works for you if you already have a working config:
-download 2.8.4 ISO from the downloads page
-burn to a USB
-boot the PC from said USB - do NOT install
-use file explorer to find the config on the internal drive
-make a copy of the configs folder to be safe
-open the copy of the config folder
-find the file that ends up in .ini
-right click on it, select open with
-near the bottom click on "use custom command" or similar
-type linuxcnc
-enter
That should run the machine as usual so you can check if it drops the link or errors out.
If that is successful you can install on internal hard drive.
11 months 2 weeks ago #338369 by Jensner
Hey Tommy,
many thanks for your support.
At the moment i would like trying to solve it at this configuration.
The last 3 days i installed everything new (serveral times). with Probe basic, IRQ-Optimization, automatic tool probe.
At the moment everything works very well, only thisone problem.
Is there no way just use another driver or kernel?
Here some infos from ethtool.
Maybe there ist something, that could fix the problem.
cnc@CNCRechner:~$ sudo ethtool enp1s0 Settings for enp1s0:     Supported ports: [ TP ]     Supported link modes:   10baseT/Half 10baseT/Full                             100baseT/Half 100baseT/Full                             1000baseT/Full     Supported pause frame use: Symmetric Receive-only     Supports auto-negotiation: Yes     Supported FEC modes: Not reported     Advertised link modes:  Not reported     Advertised pause frame use: No     Advertised auto-negotiation: No     Advertised FEC modes: Not reported     Speed: 100Mb/s     Duplex: Full     Auto-negotiation: off     Port: Twisted Pair     PHYAD: 0     Transceiver: internal     MDI-X: Unknown     Supports Wake-on: pumbg     Wake-on: g         Current message level: 0x00000033 (51)                                drv probe ifdown ifup     Link detected: yes
11 months 2 weeks ago #338371 by Jensner
I did a nother check in my BIOS and maybe i did annother improvement.
The ping performance looks mutch better then before.
--- 10.10.10.10 ping statistics --- 120393 packets transmitted, 120393 received, 0% packet loss, time 120405ms rtt min/avg/max/mdev = 0.049/0.106/0.306/0.031 ms
Maybe this could solve the problem.
Fingers crossed...
Jens
11 months 2 weeks ago #338382 by tommylight
Yes, that looks much better.
Moderators: PCW, jmelson
Time to create page: 0.378 seconds
