- Thank you received: 58
I think that would be right because the 8168 driver is not part ot the default kernel. The dkms driver compiles and installs kernel source. THis is why you need the linux-headers for your kernel. dkms should also recompile the driver if you install a different kernel.That looks good Rod, thank you. I had previously just jumped to the driver section.
For the record, it appears that both updating the driver and setting the kernel parameters are needed. I did a fresh install and just changed the kernel parameters and still encountered the problem.
Once I also updated the ethernet drivers the issue was resolved.
