Mesa 7i96s connected but inputs not working
17 Jul 2024 07:18 - 21 Jul 2024 04:43 #305478 by manfrel
Hello
I recently bought the Mesa 7i96s to upgrade my cnc machine.
I switched the jumper to change the ip address, powered it and connected it to my pc. I can ping it, and read the hostmot2 configuration with mesaflash, so far so good.
But then I realised that the end switches don't work. So I monitored the input pins under Hal configuration (LinuxCNC, axis 2.9.3) and then connected 5V from the board's power supply to the inputs, and no pin showed a response.
Is it me or the board that is at fault?
Last edit: 21 Jul 2024 04:43 by manfrel.
17 Jul 2024 07:24 #305481 by rodw
Replied by rodw on topic Mesa 7i96s connected but not working
There are a lot of things you can get wrong.
My video covers most of the bases for a mesa card
The following user(s) said Thank You: JackRay
  • Moderator
  • Moderator
17 Jul 2024 08:09 #305485 by tommylight
Replied by tommylight on topic Mesa 7i96s connected but not working
Did you also connect the input common?
17 Jul 2024 09:23 #305491 by PCW
Replied by PCW on topic Mesa 7i96s connected but not working
As tommylight suggested, you must connect the 7I96/7I96S input common (TB3 pin 12)
for the inputs to work. The inputs are fully isolated and have no connection to the
rest of the 7I96S. If you want +5V to activate the inputs, you must connect the input
common pin to 5V GND.
17 Jul 2024 14:53 #305535 by manfrel
Replied by manfrel on topic Mesa 7i96s connected but not working
Thank you all very much for your help. Input common wasn't connected, now it's working.
11 Nov 2024 13:17 #314276 by JackRay
Replied by JackRay on topic Mesa 7i96s connected but not working
hello ,
your video explains very well the basic connections and it's very welcome because at the beginning it's not easy to understand everything. I've just bought a 7i96s to replace my SV2 card (parallel port) mainly to add position feedback for my axes (encoders). The middle and end of travel connections for my 5 axes are operational and work very well with a Raspberry pi4. Where I'm having a lot of trouble is with the connections and signals from my encoder.
I want to connect the position feedback of my B axis to the only encoder port on the board.
My encoder is type A+,B+,0V,5Vdc . But I don't understand the documentation for the Mesa 7i96s board with TX/RX 422/485 ... I have no signal feedback in the halmeter.
Could you please guide me to the right connections and signals for my configuration? If attached the configuration of my B axis in my . Hal
---closedloop stepper signals---
net b-pos-cmd <= joint.3.motor-pos-cmd
net b-vel-cmd <= joint.3.vel-cmd
net b-output => [HMOT](CARD0).stepgen.03.velocity-cmd
#net b-pos-fb <= [HMOT](CARD0).stepgen.03.position-fb
net b-pos-fb => joint.3.motor-pos-fb
net b-enable <= joint.3.amp-enable-out
net b-enable => [HMOT](CARD0).stepgen.03.enable
setp [HMOT](CARD0).encoder.00.counter-mode 0
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
setp [HMOT](CARD0).encoder.00.scale [JOINT_3]ENCODER_SCALE
net b-pos-fb <= [HMOT](CARD0).encoder.00.position
net b-vel-fb <= [HMOT](CARD0).encoder.00.velocity
net b-index-enable joint.3.index-enable <=> [HMOT](CARD0).encoder.00.index-enable
net b-pos-rawcounts <= [HMOT](CARD0).encoder.00.rawcounts
# ---setup home / limit switch signals---
net b-home-sw => joint.3.home-sw-in
net b-neg-limit => joint.3.neg-lim-sw-in
net b-pos-limit => joint.3.pos-lim-sw-in
Thank you very much
11 Nov 2024 13:31 - 11 Nov 2024 13:32 #314278 by PCW
There is a RS-485 port on the 7I96S but its unrelated to the encoder input.
One thing necessary for the encoder input to work with your single ended encoder
is to jumper the 7I96S encoder input for TTL/Single ended signals. This means jumpers
W1,W2,W3 must all be in the left hand position.
Last edit: 11 Nov 2024 13:32 by PCW.
12 Nov 2024 12:07 #314337 by JackRay
thank you very much , I will go try that ASAP
Moderators: PCW, jmelson
Time to create page: 0.197 seconds
