RCpwmgen
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
20 Jul 2024 01:19 #305676 by Project_Hopeless
RCpwmgen was created by Project_Hopeless
I tried following the RCServoTest tutorial that uses pwmgen, and I'm not having any luck.  More searching and I'm thinking I should be using rcpwmgen?
Can anyone point me in the direction of a tutorial or example how to use rcpwmgen?
20 Jul 2024 02:44 #305679 by PCW
Replied by PCW on topic RCpwmgen
There's this:
  • Project_Hopeless
  • Elite Member
  • Elite Member
21 Jul 2024 00:09 - 21 Jul 2024 00:16 #305737 by Project_Hopeless
Replied by Project_Hopeless on topic RCpwmgen
 I reverted back to using PWMgen vs RCpwmgem, I just found more examples to reference.In my rservo_2.hal I commented the last line out as it kept posting an error.I'm close but I think I missing HAL pin assignments in the Main.HAL for the BOB PWM channel.  Or is it more than that?As always any guidance is appreciated.
File Name: main_2024-07-20.hal
File Size:3 KB
File Name: rcservo_2.hal
File Size:1 KB
File Name: rcservo_test01.ini
File Size:2 KB
File Name: IO_Map_read.txt
File Size:7 KB
Last edit: 21 Jul 2024 00:16 by Project_Hopeless.
21 Jul 2024 00:24 #305738 by PCW
The rcpwmgen should be much easier to setup
as it does not require adding external components
to set the offset. It addition it has higher resolution
  • Project_Hopeless
  • Elite Member
  • Elite Member
21 Jul 2024 14:58 - 21 Jul 2024 15:00 #305789 by Project_Hopeless
My 7i96s I/O map reports one pwm function and pin function.  In some examples I came across, I saw mapping with a rcpwm function associated with a pwm pin function.  Are the they one and the same?
Is there a rcpwm component to load...  loadrt rcpwmgen output_type=0  and/or do I just call it a rcpwm pin... setp rcpwmgen.0
One side note, MesaCT reports one pwm on my card but the HAL config shows two. Just curious why this is.
Last edit: 21 Jul 2024 15:00 by Project_Hopeless.
21 Jul 2024 15:38 - 21 Jul 2024 15:50 #305790 by PCW
There is no loadrt line for firmware modules.
loadrt is use to load software components (like the software pwmgen)
If the specific firmware contains a pwmgen or rcpwmgen, that module
is available without any loadrt or addf.
To use the rcpwm, you would need firmware that includes the rcpwm
module, for example, 7i96s_5abobrcd.bin has 4 RCPWMgens on the 7I96S's
P1 connector.
The MesaCT inconsistency is probably because the on card PWMgen
on the 7I96S is "hidden" by being assigned as a "local" function.
This was done to maintain GPIO compatibility with the 7I96.
You can show local I/O pins with mesaflash's --printlio command
Last edit: 21 Jul 2024 15:50 by PCW.
  • Project_Hopeless
  • Elite Member
  • Elite Member
21 Jul 2024 16:29 #305797 by Project_Hopeless
Under MesaCT I don't see that particular firmware as an option, and none have rcpwm.
When I go to the Mesa site to download that firmware it comes up "account suspend"!
Is there another location to grab firmware files?
21 Jul 2024 16:34 - 21 Jul 2024 16:58 #305799 by PCW
The store should be back online (had to update the DNS so make take a while to propagate)
In the mean time, this should work:
freeby.mesanet.com/software/parallel/7i96s.zip
Last edit: 21 Jul 2024 16:58 by PCW.
The following user(s) said Thank You: Project_Hopeless, my1987toyota
21 Jul 2024 20:15 #305814 by my1987toyota
Replied by my1987toyota on topic RCpwmgen
I was hoping it wasn't due to the crowd strike debacle.
21 Jul 2024 20:18 #305815 by PCW
Nah, it was my late and careless editing of our DNS records
after our hosting provider moved servers around...
The following user(s) said Thank You: my1987toyota
Moderators: PCW, jmelson
Time to create page: 0.167 seconds
