RCpwmgen
- Project_Hopeless
- Thank you received: 10
20 Jul 2024 01:19 #305676
by Project_Hopeless
RCpwmgen was created by Project_Hopeless
I tried following the RCServoTest tutorial that uses pwmgen, and I'm not having any luck. More searching and I'm thinking I should be using rcpwmgen?
Can anyone point me in the direction of a tutorial or example how to use rcpwmgen?
- Thank you received: 5334
20 Jul 2024 02:44 #305679
Replied by PCW on topic RCpwmgen
There's this:
- Project_Hopeless
21 Jul 2024 00:09 - 21 Jul 2024 00:16 #305737
by Project_Hopeless
Replied by Project_Hopeless on topic RCpwmgen
I reverted back to using PWMgen vs RCpwmgem, I just found more examples to reference.In my rservo_2.hal I commented the last line out as it kept posting an error.I'm close but I think I missing HAL pin assignments in the Main.HAL for the BOB PWM channel. Or is it more than that?As always any guidance is appreciated.
Last edit: 21 Jul 2024 00:16 by Project_Hopeless.
21 Jul 2024 00:24 #305738
The rcpwmgen should be much easier to setup
as it does not require adding external components
to set the offset. It addition it has higher resolution
- Project_Hopeless
21 Jul 2024 14:58 - 21 Jul 2024 15:00 #305789
by Project_Hopeless
Is there a rcpwm component to load... loadrt rcpwmgen output_type=0 and/or do I just call it a rcpwm pin... setp rcpwmgen.0
One side note, MesaCT reports one pwm on my card but the HAL config shows two. Just curious why this is.
My 7i96s I/O map reports one pwm function and pin function. In some examples I came across, I saw mapping with a rcpwm function associated with a pwm pin function. Are the they one and the same?The rcpwmgen should be much easier to setup
Last edit: 21 Jul 2024 15:00 by Project_Hopeless.
21 Jul 2024 15:38 - 21 Jul 2024 15:50 #305790
There is no loadrt line for firmware modules.
loadrt is use to load software components (like the software pwmgen)
If the specific firmware contains a pwmgen or rcpwmgen, that module
is available without any loadrt or addf.
To use the rcpwm, you would need firmware that includes the rcpwm
module, for example, 7i96s_5abobrcd.bin has 4 RCPWMgens on the 7I96S's
P1 connector.
The MesaCT inconsistency is probably because the on card PWMgen
on the 7I96S is "hidden" by being assigned as a "local" function.
This was done to maintain GPIO compatibility with the 7I96.
You can show local I/O pins with mesaflash's --printlio command
P1 connector.
Last edit: 21 Jul 2024 15:50 by PCW.
- Project_Hopeless
21 Jul 2024 16:29 #305797
by Project_Hopeless
Under MesaCT I don't see that particular firmware as an option, and none have rcpwm.
When I go to the Mesa site to download that firmware it comes up "account suspend"!
Is there another location to grab firmware files?
21 Jul 2024 16:34 - 21 Jul 2024 16:58 #305799
The store should be back online (had to update the DNS so make take a while to propagate)
In the mean time, this should work:
freeby.mesanet.com/software/parallel/7i96s.zip
Last edit: 21 Jul 2024 16:58 by PCW.
The following user(s) said Thank You: Project_Hopeless, my1987toyota
- my1987toyota
- Online
- Thank you received: 449
21 Jul 2024 20:15 #305814
by my1987toyota
Replied by my1987toyota on topic RCpwmgen
I was hoping it wasn't due to the crowd strike debacle.The store should be back online (had to update the DNS so make take a while to propagate)
21 Jul 2024 20:18 #305815
Nah, it was my late and careless editing of our DNS records
after our hosting provider moved servers around...
The following user(s) said Thank You: my1987toyota
Time to create page: 0.691 seconds
