7i96s (6 step generators)?
- Masiwood123
- Thank you received: 93
28 Jul 2024 19:01 #306266
by Masiwood123
7i96s (6 step generators)? was created by Masiwood123
Hello,
I am planning to make a machine with 5 axes, I have a 7i96s that supports it, but i have to make a tandem for the x axis so that i will have 6 motors(two identical)... is there a chance for additional step generator trough P1(BOB)? Thank you
- Thank you received: 7490
28 Jul 2024 19:03 #306267
Replied by tommylight on topic 7i96s (6 step generators)?
Yes, 5 more, so have a look at the downloaded firmwares from Mesa website, there might be something already there, or it might even be the default.
The following user(s) said Thank You: Masiwood123
- Thank you received: 5334
28 Jul 2024 19:11 #306268
Replied by PCW on topic 7i96s (6 step generators)?
7i96s_5abobd.bin
Adds 5 stepgens for the common Sainsmart 5 Axis BOB
There are similar configs for Mesa 7I78 and 7I85S daughtercards
- Masiwood123
28 Jul 2024 19:18 #306270
by Masiwood123
Replied by Masiwood123 on topic 7i96s (6 step generators)?
thanks guys, then the problem is solved, I just have to make the machine
thanks again
