7I97T PWMGen Dither and Firmware Version
30 Jul 2024 02:02 - 30 Jul 2024 02:02 #306374 by AirRacer
LinuxCNC Version 2.9.2
Mesa 7I97T + 7I76 Firmware 7I97t_7;i76d
Mesaflash 3.5.9
When attempting to enable PWM Dithering I'm getting the resulting error:
     ./main.hal:63: parameter or pin 'hm2_7i97.0.pwmgen.00.dither' not found
I see in the HOSTMOT2 manual that "PWMGen firmware version 1 or greater" is required for dither.  Is this the problem?  How can I determine which version of the PWMGen firmware my card has on it?  Is this the likely issue?
Thanks,
Skylor
Last edit: 30 Jul 2024 02:02 by AirRacer.
30 Jul 2024 02:39 #306375 by PCW
You can determine module versions with mesaflash's --readhmid option
30 Jul 2024 04:21 #306376 by PCW
Its possible only the base configuration (7i97t_d.bin) has been
updated to include version 1 PWMgens
7I97T+7I76 with version 1 PWM firmware:
File Name: 7i97t_7i76d.zip
File Size:303 KB
30 Jul 2024 05:50 #306379 by AirRacer
Replied by AirRacer on topic 7I97T PWMGen Dither and Firmware Version
Thank you!
16 Mar 2025 00:44 #324030 by gwond
Replied by gwond on topic 7I97T PWMGen Dither and Firmware Version
I'm having the same issue, but with a 7i97T + 7i78.  PWM Version is reporting 0 when doing the HMID Read.
Could you please provide the updated firmware for this combination as well?  Additionally, I'll be using a THCAD with QTPlasmaC.  Is there any custom firmware needed?  Not planning to use an additional THCAD for Ohmic sensing currently.
16 Mar 2025 01:13 - 16 Mar 2025 01:14 #324031 by PCW
File Name: 7i97t_7i78d.zip
File Size:294 KB
No special firmware is needed for THCAD (if you have a free encoder)
Last edit: 16 Mar 2025 01:14 by PCW.
16 Mar 2025 02:00 #324034 by gwond
Thanks for the quick reply, problem resolved! Now I seem to be running into troubles configuring the stepgen on the 7i78. Do I need to call that board out separately or include stepgens in the board config for the 7i97T?
Here is what I have in the main.hal
loadrt [HM2](DRIVER) board_ip=[HM2](ADDRESS) config="sserial_port_0=00000000 num_encoders=6 num_pwmgens=6 num_stepgens=0"
It is failing here:  net joint-2-enable => hm2_7i78.0.stepgen.02.enable
main.hal:255 Pin hm2_7i78.0.stepgen.02.enable does not exist
16 Mar 2025 02:14 #324037 by PCW
should be
net joint-2-enable => hm2_7i97.0.stepgen.02.enable
Moderators: PCW, jmelson
Time to create page: 0.109 seconds
