Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD
- scda
- Thank you received: 3
12 Aug 2024 14:43 - 12 Aug 2024 14:49 #307547
by scda
Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD was created by scda
Hi all
My retrofit control box is starting to take shape. I use a 7i96s + 7i85 (+7i84D smart serial) card. I would like to use the Mesa modbus on the 7i96s' smart serial port for Modbus (to control my VFD).
Is there a firmware for that available or can someone compile one for me?
Do you think standard mesa modbus works with Huanyang VFD (since these VFDs don't use proper Modbus)? In the comp file I can only define the registers but not the whole data stream to be sent and received form the vfd.
Cheers,
David
Cheers,
David
Last edit: 12 Aug 2024 14:49 by scda.
- Thank you received: 5334
12 Aug 2024 18:36 #307579
Replied by PCW on topic Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD
I would think it would be simpler to use a 0-->10V analog spindle speed control
Also, I'm not sure if the Mesa MODBUS interface would work with the Huantyang
- scda
12 Aug 2024 18:47 #307582
by scda
Replied by scda on topic Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD
Hi PCW. Ok thanks for the reply. This was my backup plan, so I will probably go this route then and leave the modbus stuff for another project.
Cheers,
David
Cheers,
David
Time to create page: 0.082 seconds
