newbie issues with mesa 5i20 and 7i36 daughtercard.
2 years 2 months ago #308569 by jroise
I had an configuration that almost worked with the 5i20 and a 7i33 but I found that one of the pins on the 7i33 was stuck high so I ordered what looked like the next closest model available. I plugged in the new card started LinuxCNC and nothing seemed broken so I tried using the enable and encoder input pins with my current configuration and that didn't seem to be working. where do i begin looking to figure this out?do I need a different bit file?or is it a different HAL configuration?
this is my dmesg output below.
2 years 2 months ago #308570 by PCW
Ok the first thing needed is firmware for the 5I20 that supports the 7I36
(the 7I36 has a very different pinout than the 7I33)
I can build this when I get a chance.
Supporting the 7I36 isolated inputs and encoder signal drive detection may
be a bit awkward unless you have upgraded LinuxCNC to at least version 2.8.4
as these features use the inm firmware module which is not supported by earlier
LinuxCNC versions.
2 years 2 months ago #308607 by jroise
Wow thanks!
I should upgrade my version anyways (I'm on EMC 2.3.2)
it looks like 2.9.3 is the most recent I'll upgrade to that.
2 years 2 months ago #308858 by PCW
5I20 configuration for 1 7I36 on P4
File Name: 5i20_7i36x1d.zip
File Size:132.08 KB
Sorry it took so long, needed to update the older 5I20 source
to support the new inmux module
2 years 2 months ago #308944 by jroise
thank you so much!
1 year 1 month ago #335359 by rasuran
"Dear friend,
I am working on retrofitting a grinding machine and I have prepared the following hardware for it: Mesa 5i22-1.5 + 2x 7i36 + 7i44 + 7i70 + 7i72 + 7i73. I would kindly like to ask if it would be possible to create firmware for this combination.
Thank you very much in advance."
Moderators: PCW, jmelson
Time to create page: 0.059 seconds
