newbie issues with mesa 5i20 and 7i36 daughtercard.
25 Aug 2024 01:18 #308569 by jroise
I had an configuration that almost worked with the 5i20 and a 7i33 but I found that one of the pins on the 7i33 was stuck high so I ordered what looked like the next closest model available. I plugged in the new card started LinuxCNC and nothing seemed broken so I tried using the enable and encoder input pins with my current configuration and that didn't seem to be working. where do i begin looking to figure this out?do I need a different bit file?or is it a different HAL configuration?
this is my dmesg output below.
25 Aug 2024 01:28 #308570 by PCW
Ok the first thing needed is firmware for the 5I20 that supports the 7I36
(the 7I36 has a very different pinout than the 7I33)
I can build this when I get a chance.
Supporting the 7I36 isolated inputs and encoder signal drive detection may
be a bit awkward unless you have upgraded LinuxCNC to at least version 2.8.4
as these features use the inm firmware module which is not supported by earlier
LinuxCNC versions.
25 Aug 2024 15:56 #308607 by jroise
Wow thanks!
I should upgrade my version anyways (I'm on EMC 2.3.2)
it looks like 2.9.3 is the most recent I'll upgrade to that.
28 Aug 2024 00:57 #308858 by PCW
5I20 configuration for 1 7I36 on P4
File Name: 5i20_7i36x1d.zip
File Size:132 KB
Sorry it took so long, needed to update the older 5I20 source
to support the new inmux module
29 Aug 2024 15:44 #308944 by jroise
thank you so much!
24 Sep 2025 09:54 #335359 by rasuran
"Dear friend,
I am working on retrofitting a grinding machine and I have prepared the following hardware for it: Mesa 5i22-1.5 + 2x 7i36 + 7i44 + 7i70 + 7i72 + 7i73. I would kindly like to ask if it would be possible to create firmware for this combination.
Thank you very much in advance."
24 Sep 2025 15:52 #335370 by PCW
5I22-1.5 firmware for:
7I36 on P2 (PWM/ENC 0..3 sserial port 0 chan 0)
7I36 on P3 (PWM/ENC 4..7 sserial port 0 chan 1)
7I44 on P4 (sserial port 1 channels 0..7)
File Name: 5i22b_svss...6x2d.zip
File Size:179 KB
Moderators: PCW, jmelson
