help to connect alarm signal driver hbs86h
30 Aug 2024 13:41 #309019 by Ismacr63
I want to connect the alarm signal of my drivers to the typical blue Chinese parallel port card.
I've looked around the net a lot but I'm not sure how to connect it. From what I see the alarm signal is normally open, I've inverted it to normally closed by connecting via RS232.
My idea is to connect the 3 drivers in series together with the emergency stop.
I don't know if anyone can give me an idea of ​​how to connect everything.
30 Aug 2024 13:45 #309021 by tommylight
Replied by tommylight on topic help to connect alarm signal driver hbs86h
Connect to input on BOB, then in hal connect that input to joint.N.amp-fault.
Or in your case if you have them with e-stop, in hal connect to estop-ext.
The following user(s) said Thank You: Ismacr63
30 Aug 2024 16:12 #309032 by Ismacr63
Replied by Ismacr63 on topic help to connect alarm signal driver hbs86h
In hal I have pin 10 connected to estop-exp.
I don't know how I should connect the alarm cables.... I have right now connected alm+ to input 10 of the bob and alm- on the ground.
If I create a fault in the driver so that the alarm goes off and linuxcnc stops but the driver does not emit a red light or any warning.
If I create the fault without connecting the cables, the red LED flashes.
30 Aug 2024 21:56 #309057 by Benb
Parallèle port driver setup linuxcnc.org/docs/devel/html/hal/parallel-port.html
For wiring your IO’s, have a look at the wiring diagram forum.linuxcnc.org/27-driver-boards/5000...ation-help-mesa-5i25
Hope these links are helpful.
31 Aug 2024 15:16 #309094 by Ismacr63
The problem I have is that I don't know how to connect the cables from the driver to the bob. I also don't know if alarm+ needs voltage.....
31 Aug 2024 15:50 #309095 by Ismacr63
Apart from the cable connection, do I have to modify anything in my HAL file so that the alarm works with the emergency stop?
31 Aug 2024 16:02 #309098 by tommylight
No need, it should work as is.
Do you have enable wired to your drives?
31 Aug 2024 16:03 #309099 by Ismacr63
Yes, they are connected
31 Aug 2024 17:19 #309102 by Ismacr63
I have managed to get linuxcnc to stop when an alarm goes off, but the driver does not turn on the red LED, so I will never know which driver is faulty...
01 Sep 2024 02:44 #309123 by tommylight
Of course, hence my question.
To have it work properly, you need separate inputs for all drives, then LinuxCNC shows what drive faulted.
Moderators: PCW, jmelson
Time to create page: 0.856 seconds
