help to connect alarm signal driver hbs86h
2 years 2 months ago #309098 by tommylight
No need, it should work as is.
Do you have enable wired to your drives?
The following user(s) said Thank You: Ismacr63
2 years 2 months ago #309099 by Ismacr63
Yes, they are connected
2 years 2 months ago #309102 by Ismacr63
I have managed to get linuxcnc to stop when an alarm goes off, but the driver does not turn on the red LED, so I will never know which driver is faulty...
2 years 2 months ago #309123 by tommylight
Of course, hence my question.
To have it work properly, you need separate inputs for all drives, then LinuxCNC shows what drive faulted.
2 years 2 months ago #309131 by Ismacr63
Yes, I understand you but I don't have input for each driver. I don't care that linuxcnc tells me which driver is wrong. I just need it to come to a stop when that happens.
The problem is that when the driver fails the red LED does not light up. On the other hand, if I disconnect the driver from the bob, the red LED does turn on. I am doing all the tests with a single driver and the only input I have free.
2 years 2 months ago - 2 years 2 months ago #309134 by chris@cnc
you have to collect signals from all amplifiers via a relay and connect it to one input  of your Bob. As a bonus, I would connect LEDs to show who is in pain.
Last edit: 2 years 2 months ago by chris@cnc.
Moderators: PCW, jmelson
Time to create page: 0.096 seconds
