7i96s Extra I/O Daughter Board Selection
  • Trevy3
  • Trevy3's Avatar Topic Author
  • Junior Member
  • Junior Member
14 Sep 2024 05:33 #310112 by Trevy3
I am currently using a 7i96s board to run my mill. When all is done, it will be a 4 axis machine with ATC. However, I have already run out of I/O (mainly outputs), so I'm looking to get a daughter card for expanding that. I would prefer it to be a serial card instead of a P1 connection as I am using the P1 connector for an MPG pendant.
I am planning on having the outputs mainly running relays for sub-spindle control and pneumatic cylinders. The sub-spindle would just be using the same 0-10V signal that the main spindle uses, but with a different set of relays. Maybe connecting a few limit switches on the inputs as well.
I was looking at boards and saw the 7i84 and was wondering if this would be a reasonable selection for this use case. I'm not very familiar with the daughter cards that mesa offers and there are so many of them. Perhaps the 7i73 would be the better option here since I want to add the MPG? That would allow the P1 connector to stay open, but I'm not sure I'd ever need the P1 for anything else and I already have the P1 MPG firmware loaded.
Any input here would be great. I've never run a daughter card before.
  • Platinum Member
  • Platinum Member
14 Sep 2024 06:45 #310115 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic 7i96s Extra I/O Daughter Board Selection
I’d jump that way.
  • Moderator
  • Moderator
14 Sep 2024 12:29 #310138 by tommylight
Replied by tommylight on topic 7i96s Extra I/O Daughter Board Selection
7i73 has low voltage IO as it is made for control pannels, so get the 7i84, it should also do 2 of MPG in Mode 1 or 2.
The following user(s) said Thank You: Trevy3
  • Trevy3
  • Junior Member
  • Junior Member
14 Sep 2024 19:45 #310163 by Trevy3
Replied by Trevy3 on topic 7i96s Extra I/O Daughter Board Selection
Ok, I might go with that then, thanks.
  • Moderator
  • Moderator
14 Sep 2024 21:50 #310169 by tommylight
FYI, i have used a Mesa 7i84 for the control panel on my Mazak, although i have a Mesa 7i73, would have needed a lot of level changes, especially since it uses an old +-12V MPG encoder.
Versatility is a very strong feature of Mesa cards, and i like that, a lot! :)
Moderators: PCW, jmelson
Time to create page: 0.099 seconds
