Latency test marginaly poor
- PhilipME
- Thank you received: 14
22 Sep 2024 09:20 #310589
by PhilipME
Latency test marginaly poor was created by PhilipME
the latency test stays most of the time around 30k for the base thread. But ocasionally climb up to 50k
I am using mesa 7i96s
My question does the mesa cares about latency performance?
Good day
Philip
Good day
Philip
- juliankoenig87
- Thank you received: 55
22 Sep 2024 11:02 #310591
by juliankoenig87
Replied by juliankoenig87 on topic Latency test marginaly poor
Short answer. No, 50k are sufficient.
Really important is the network time. Otherwise you will get readerrors with standard 1ms servo thread period.
Try to aim for vetter than 300us ping time. (use the scope with read time and calculate to ms - feadings are in clocks- to see network and latency in combination)
Best regards
Julian
Best regards
Julian
The following user(s) said Thank You: PhilipME
- Online
- Thank you received: 7490
22 Sep 2024 11:26 #310592
Replied by tommylight on topic Latency test marginaly poor
Do you get latency warnings when running LinuxCNC ?
If not, do not worry about it, all is good.
LinuxCNC is very good at reporting issues.
- PhilipME
22 Sep 2024 13:26 #310598
by PhilipME
Replied by PhilipME on topic Latency test marginaly poor
For the limited time I ran, I did not get any warningDo you get latency warnings when running LinuxCNC ?
- Online
22 Sep 2024 13:46 #310601
OK, no worries then, make chips and enjoy.
- PhilipME
22 Sep 2024 18:03 #310613
by PhilipME
