Mesa 7i96s with 5 encoders and Modbus
- nartburg
25 Sep 2024 15:45 #310785
by nartburg
Replied by nartburg on topic Mesa 7i96s with 5 encoders and Modbus
OK, standard not self "compiled" 7i96sd_pktv2.bin
and afforementioned relayboard.mod
still nothing
still nothing
- Thank you received: 5334
25 Sep 2024 15:51 #310786
Replied by PCW on topic Mesa 7i96s with 5 encoders and Modbus
Not sure.
Hal file issues?
Measurement issues?
Hal file issues?
Measurement issues?
- nartburg
25 Sep 2024 16:04 #310789
by nartburg
Hal file issues ? Doubt it the compenent is loading and running (HAL Show config)
Measurement issues? Dito, attaching an oszi between ground and tx is not so a big deal.
5Volts with some ripples at 15kHz from the vfd
25 Sep 2024 21:01 #310798
Just tested relayboard.mod with LinuxCNC 2.9.3
and 7I96S with 7i96sd_pktv2.bin and this hal/ini file set:
And it's working as expected (busy clicking away)
- nartburg
26 Sep 2024 09:20 #310817
by nartburg
Nothing, njente, nada 5Volts
The encoder input on TB2 is not working either -- that's what got me into implementing the other encoder inputs on P1 as seen in the .vhd
(output of mesaflash -read):
P1-01/DB25-01 34 IOPort QCount 1 Quad-A (In)
P1-02/DB25-14 35 IOPort QCount 1 Quad-B (In)
P1-03/DB25-02 36 IOPort QCount 2 Quad-A (In)
P1-04/DB25-15 37 IOPort QCount 2 Quad-B (In)
P1-05/DB25-03 38 IOPort QCount 3 Quad-A (In)
P1-06/DB25-16 39 IOPort QCount 3 Quad-B (In)
P1-07/DB25-04 40 IOPort QCount 4 Quad-A (In)
P1-08/DB25-17 41 IOPort QCount 4 Quad-B (In)
P1-09/DB25-05 42 IOPort QCount 5 Quad-A (In)
P1-11/DB25-06 43 IOPort QCount 5 Quad-B (In)
and as I was planning to use sserial for some other things I tried to implement an additional pktUart port on P1 as well
(mesaflash output):
P1-13/DB25-07 44 IOPort PktUARTTX 0 TXData (Out)
P1-15/DB25-08 45 IOPort PktUARTRX 0 RXData (In)
So let us assume that this part of the board emitted magic smoke.
I'm going to open a new topic to explore this possible workaround.
thx to PCW
(mesaflash output):
thx to PCW
