7i96 MPG Encoder A- B-
- upplib
28 Sep 2024 15:10 #311000
by upplib
7i96 MPG Encoder A- B- was created by upplib
New to LinuxCNC - I added an MPG to the Spindle Encoder of Mesa 7i96. Initially I had only A+ B+ 5V GND on TB2 Connector and it was having trouble moving and was registering only 1 count in Hal. Going thru the forum comments, I removed the 5V from TB2 and connected it to the main 5V supply. I was able to move the axis and able see the counts. However it would not reverse, so i connected the A- B- and it started working both forward and reverse.
Any reason, I need to connect the A-B-? because the posts mention A+ B+. The TB2 provides only 4.4V and my MPG says 5V-15V could that be a reason for not able to use the TB2 5V?
babu
babu
- Thank you received: 5337
28 Sep 2024 17:27 #311006
Replied by PCW on topic 7i96 MPG Encoder A- B-
If you have differential outputs (A+,A- ,B+,B-for example)
you should jumper the 7I96 encoder inputs to differential mode
and use all 6 wires.
If you want to use single ended mode (only A+,B+)
you need to jumper the 7I96 encoder input for single
ended mode.
ended mode.
- Thank you received: 7504
28 Sep 2024 17:31 #311007
Replied by tommylight on topic 7i96 MPG Encoder A- B-
Moved to "driver boards" section.
- upplib
29 Sep 2024 08:07 #311025
by upplib
Replied by upplib on topic 7i96 MPG Encoder A- B-
Thanks that worked, also the +5V GND on the encoder section also works. No need to provide separate power to MPG.
thanks
thanks
Time to create page: 0.080 seconds
