Mesa 7i96s --USB error finishing read
  • Moderator
  • Moderator
14 Oct 2024 14:49 #312065 by tommylight
Replied by tommylight on topic Mesa 7i96s --USB error finishing read
Not sure if it will help much, but only connect your motor cable shield at the drive end. instead of both ends.
Sometimes it does help, a lot, although only once in my experience, the rest (probably over 10) both sides worked better.
All VFD's i have used have separate ground pins for mains and for motor, probably have some LC filter inside but i never checked, waiting for one of those to die so i can open it. :)
Another thing i noticed with a cheap 2.2KW HY-whatever VFD was that grounding the motor wires on both sides would make it possible to use it without mains grounding at all, hence the above assumption on LC filtering.
16 Oct 2024 09:38 #312230 by nartburg
Replied by nartburg on topic Mesa 7i96s --USB error finishing read
Got the optical isolated rs485 adapter.
Works!
But it was quite a pain.
Moderators: PCW, jmelson
Time to create page: 0.106 seconds
