solved: TB6 Inputs missing in MESA 7i95T
  • JanMrlth
  • JanMrlth's Avatar Topic Author
  • New Member
  • New Member
14 Nov 2024 19:12 - 15 Nov 2024 20:48 #314475 by JanMrlth
Hi,I have refurbished an older ISEL Gantry CNC with a MESA 7i95T. (Only because 7i76ed was Out of stock..)All is working fine, exept one little detail:I can not find any of the Inputs in the hal, that are connected to TB6.
I have flashed the 1_pktv2 Firmware, to use RS485/Modbus with my frequency converter for the spindle. When I check the board with halrun, everything works fine. Exept, that I do not have any Inputs at TB6 listed.
The LEDs light up. So physically everything should be fine.
photos.app.goo.gl/H1fraX8DV1ccoN6j9
photos.app.goo.gl/62hDPX6Bzrdr1kGS7
Any Idea where I would find them? Is there anything else that needs to be configured?
Thanks a lot!
Cheers
Jan
Last edit: 15 Nov 2024 20:48 by JanMrlth.
14 Nov 2024 19:43 #314478 by PCW
The 7I95 isolated inputs are "inmux" pins
When LinuxCNC is running:
halcmd show pin *inmux*
  • JanMrlth
  • New Member
  • New Member
15 Nov 2024 20:47 #314564 by JanMrlth
Replied by JanMrlth on topic solved: TB6 Inputs missing in MESA 7i95T
Thank you.
15 Nov 2024 20:57 #314567 by PCW
Also I don't think pncconf supports the 7I95/7I95T but MesaCT does.
Moderators: PCW, jmelson
Time to create page: 0.095 seconds
