PC for Mesa 5i25T
- Thank you received: 5334
25 Dec 2024 14:52 #317353
Replied by PCW on topic PC for Mesa 5i25T
I would first verify that you have 5V at the 7I77 in case this is an analog
output voltage issue.
Another possibility is encoder count rate issues, especially if there is significant
quadrature distortion. You can try disabling the encoder filter to test this.
- lukin1156
07 Jan 2025 20:32 #318346
by lukin1156
Replied by lukin1156 on topic PC for Mesa 5i25T
In the end, the problem was in the switched analog signal and the GND of the analog signal. After swapping it works without a problem.
08 Jan 2025 00:41 #318368
Yeah, a shorted analog output is going to drag the (relatively weak) local
power supply down.
power supply down.
Time to create page: 0.107 seconds
