6i24 and boot / gpu
  • Nitram
  • Nitram's Avatar Topic Author
  • Elite Member
  • Elite Member
23 Nov 2024 04:31 #315079 by Nitram
6i24 and boot / gpu was created by Nitram
Hi Peter.
I have an existing 5i24 which is working fine.
I bought a backup 6i24 for redundancy a number of months ago, but have not used it as yet.
Today I was going to flash the 6i24 with the 5i24 bin file. Jumpers are configured to mimic the 5i24 board.
So I took the 5i24 out and put the 6i24 into the single lane PCIe slot.
Problem is that the computer goes through the BIOS flash, but then hangs on boot.
I have tried various other PCIe slots on the motherboard (single and multi lane) without success.
When I put the 6i24 board in I see LED's light up briefly, then immediately extinguish.
I put the 5i24 back in and the computer boots fully, and --readhmid reports correctly.
It is almost as if the computer thinks the 6i24 is a GPU and hangs there on boot because it isn't.
There are no BIOS settings to force the computer to ignore a GPU or to force it to use on-board graphics...
Peter, have you struck anything like this before, and do you have any suggestions?
Many thanks,
Marty.
23 Nov 2024 15:07 #315109 by PCW
Replied by PCW on topic 6i24 and boot / gpu
I haven not seen this kind of issue but sometimes, motherboards with x4/x8/x16 slots
won't work with a X1 card. Also make sure that the 6I24 is jumpered for 33 Mhz clock
(and all jumpers match the default jumper positions in the manual page 4.
  • Moderator
  • Moderator
23 Nov 2024 16:12 #315117 by tommylight
Replied by tommylight on topic 6i24 and boot / gpu
Can you try in BIOS setting the PCI-E mode to GEN1 for that slot?
  • Nitram
  • Elite Member
  • Elite Member
24 Nov 2024 05:12 #315163 by Nitram
Replied by Nitram on topic 6i24 and boot / gpu
Thanks Peter and Tommy.
All the board jumpers are set to 5i24 settings.
There are no options in bios for pcie settings unfortunately.
They're is a 1x pcie slot on the mb but neither this, nor any other slots will allow the computer to boot with the 6i24 in situ.
As a trial, I have another (Windows) machine. That machine boots fine and the card is visible in device manager.
I think for now I'm putting it down to something to do with the computer, possibly mother board related.
One last question though, is there a minimum version of linuxcnc which needs to be used to allow the computer to recognise a 6i24?? Could it be something as simple as missing drivers?? IIRC the last time I updated was about 18 months ago.
Thanks!!
Moderators: PCW, jmelson
Time to create page: 0.202 seconds
