7i92TF and c11g bin file
- Sziggy_NC
06 Dec 2024 08:08 #316084
by Sziggy_NC
7i92TF and c11g bin file was created by Sziggy_NC
I have a lathe with a c11g and I have a 7i92TF. Sadly the only files I can find for a c11g are for the previous version of the 7i92 non-t. I was able to make my own pin file by comparing it with the one I pulled using mesaflash.
What I don't know how to do is create the bin file.
Is this something a typical end user can do?
- Thank you received: 5334
06 Dec 2024 14:57 - 06 Dec 2024 17:05 #316110
Replied by PCW on topic 7i92TF and c11g bin file
7I92T firmware for 2X C11G
You can build these files yourself with the source supplied
in the 7i92t.zip file and using Efinixes free "Efinity" tool chain.
The pinout source file for C11G was already done (for the 7I92)
so it was just a matter of selecting that pinout source file and building
I just have not got around to building all the 7I92 configs for the 7I92T
Last edit: 06 Dec 2024 17:05 by PCW.
The following user(s) said Thank You: tommylight, Sziggy_NC
