7i33TA rigid tapping
- vre
- Thank you received: 17
06 Jan 2025 03:56 #318187
by vre
7i33TA rigid tapping was created by vre
Happy new year!
I have a mill with spindle that has 7.5kw asynchronous 3phase motor driven by inverter.
Inverter driven by -10+10V from 7i33TA also i have installed an encoder ABZ 500lines to some gear of spindle (known motor:spindle ratio)
connected to 7i33TA. How can setup spindle for rigid tapping ? Is there any howto/tutorial ?
Thank you
Thank you
- Thank you received: 5334
06 Jan 2025 14:32 #318229
Replied by PCW on topic 7i33TA rigid tapping
pncconf can set this up, though you may need to swap A/B to get the spindle direction correct
The following user(s) said Thank You: vre
Time to create page: 0.139 seconds
