- Hardware & Machines
- Driver Boards
- Connecting to FANUC αi-B βi-B (62XX) series servos to LinuxCNC system?
- liutas4x4
- Thank you received: 5
13 Jan 2025 07:12 #318857
by liutas4x4
Connecting to FANUC αi-B βi-B (62XX) series servos to LinuxCNC system? was created by liutas4x4
HI,
I am searching for hardware solution for connecting most modern FANUC servos like 0i-F to PC-based NC.
Something similar to solution Dmitry (/dm17ry) does for Mitsubishi servos.
Hope someone will show me a way.
#αi-B, #aplha i B, #alfa i B, #βi-B, #beta i B, #betha i B, #FANUC 62XX
/eugenius
/eugenius
- jmelson
- Thank you received: 126
13 Jan 2025 15:16 #318867
by jmelson
Replied by jmelson on topic Connecting to FANUC αi-B βi-B (62XX) series servos to LinuxCNC system?
I may have a board that will convert these encoders to look like standard quadrature encoders. Can you give me specific motor model numbers or encoder model numbers?
Thanks,
Jon
Thanks,
Jon
- liutas4x4
14 Jan 2025 10:27 #318935
by liutas4x4
Replied by liutas4x4 on topic Connecting to FANUC αi-B βi-B (62XX) series servos to LinuxCNC system?
Thank you for a quick response.
My target is to connect any series B FANUC motor-encoder-driver for servicing them.
/eugenius
/eugenius
- jmelson
14 Jan 2025 15:04 #318949
by jmelson
I have used this converter board for Alpha (anything) 32, 65 and 128 encoders.
I also tested it with the (alpha)iAR128 (A860-2010-T341) and it worked fine.
I had a guy who tried it with the A860-2027-X003 or β64iA encoder, and the data rate on that encoder is different. So, I don't actually know which encoders will and won't work with my converter board. But, somewhere between A860-2010 and -2027 they changed that serial data rate.
Jon
Jon
The following user(s) said Thank You: tivoi
- liutas4x4
15 Jan 2025 07:40 #319006
by liutas4x4
Two moments:
1. My target is B series Fanuc.
2. How to control with new protocol? Mesa? Connected to original Fanuc adater?
/eugenius
/eugenius
- tivoi
- Thank you received: 20
15 Jan 2025 10:58 #319012
by tivoi
Replied by tivoi on topic Connecting to FANUC αi-B βi-B (62XX) series servos to LinuxCNC system?
i guess he want control fanuc servo drive over linuxcnc
The following user(s) said Thank You: liutas4x4
- liutas4x4
15 Jan 2025 13:45 - 15 Jan 2025 13:46 #319022
by liutas4x4
Yes.
But B-series.
But B-series.
Last edit: 15 Jan 2025 13:46 by liutas4x4.
- Driver Boards
