7I96S With RS485 Servo Drivers
14 Jan 2025 16:03 #318955 by mindstormmaster1
7I96S With RS485 Servo Drivers was created by mindstormmaster1
Hey! I'm working to convert my mill from Mach3 and open loop steppers to LinuxCNC and AC Servo motors.
I would like to use the Mesa 7I96S card along with these motors and drivers.
www.omc-stepperonline.com/a6-series-1000...67-a6-rs1000h2a1-m17
From the Mesa manual, it looks like it should be possible to use these stepper drivers, but I wonder if someone could confirm that they will work together. There doesn't seem to be a ton of information about wiring the 7I96S. I mostly see examples where Step +/- and Dir +/- are used. However, that does not seem to be as common with modern servo motor drivers. Would a different card be easier to find documentation for?
14 Jan 2025 16:13 #318956 by PCW
Replied by PCW on topic 7I96S With RS485 Servo Drivers
For step/dir mode it's just:
Step+  --> Pulse+
Step-   --> Pulse-
Dir+   --> Sign+
Dir-     --> Sign-
14 Jan 2025 16:26 #318958 by mindstormmaster1
Replied by mindstormmaster1 on topic 7I96S With RS485 Servo Drivers
So I just need a DB breakout cord and then I can wire it like that and the driver will automatically take care of everything else like making sure it made it to the correct position automatically?
14 Jan 2025 16:53 #318961 by PCW
Yes, you need the appropriate D connector for CN1
Moderators: PCW, jmelson
Time to create page: 0.075 seconds
