RPi + Sipeed Tang Nano 20 k: new breakout board for LitexCNC
- TOLP2
- Thank you received: 178
18 Jan 2025 11:02 #319268
by TOLP2
RPi + Sipeed Tang Nano 20 k: new breakout board for LitexCNC was created by TOLP2
With the 5A-75B and 5A-75E we have a low cost way of creating a driver board for Linux-CNC. Based on the work of Romanetz, the project
LiteX-CNC
was started, providing a easy customizable firmware and driver to use these boards. The down-side however is that these boards require some soldering work to be done to accept inputs; I've messed up some boards in the process....
Therefore, Litex-CNC is going to be expanded to accept more FPGA's, starting with the Sipeed Tang Nano 20k. Compared with the 5A-75B it has less outputs (28 compared to 48 for the 5A-75B), but this is still enough for a simple 3 axis machine. The big advantage is that no SMT soldering skills are required to get this board up and running.
For the Raspberry-Pi I've designed a HAT, which provides:
An estimation of the HAT will be around 7 Euro's, excluding the Tang Nano 20k. Inlcuding the FPGA, the price would be around the 40 Euro price point.
- 7 extended PMOD-connectors. Each connector has 4 GPIO, power rails (+5V, max 200 mA) and a buffered enable signal;
- RS489 connector for communicating with for example a VFD;
- communication between Raspberry PI and FPGA using SPI in bidirectional mode (3-wire) to save on pins;
- conforms to the HAT+ specification , including a EEPROM with settings.
The following user(s) said Thank You: tommylight, cakeslob, Cant do this anymore bye all
- Thank you received: 2177
16 Feb 2025 10:05 #321703
Replied by Aciera on topic RPi + Sipeed Tang Nano 20 k: new breakout board for LitexCNC
Thanks for sharing.
- meister
- Thank you received: 502
19 Feb 2025 13:29 - 19 Feb 2025 13:40 #321984
by meister
Replied by meister on topic RPi + Sipeed Tang Nano 20 k: new breakout board for LitexCNC
is it possible to view the circuit diagram somewhere ?
EDIT: and how many Logic-Cells you need for a 3Axis Mill ?
Last edit: 19 Feb 2025 13:40 by meister.
Time to create page: 0.082 seconds
