Firmware issue with 6i25
- mmt
21 Feb 2025 21:46 - 21 Feb 2025 21:51 #322235
by mmt
Firmware issue with 6i25 was created by mmt
hello,
im sure this has been covered, i just cant seem to find specifically what i need.
I have an HP ProDesk 600 G1 SFF Desktop with no physical parallel port and a brand new from mesa 6i25 card.
computer has no pci sockets and 2 pci-e sockets
Installed is current stable release of debian 12 with linuxcnc 2.9. (The one and done install)
1st - install 6i25 (in both slots) and run lspci it is there. (02:00.0 DPIO module: Device 2718:5125 (rev 01))
2nd - Tried to add firmware for 6i25 and it says no card present or something to that effect
3rd - created a cnc setup with pncconfig wizard. Message (pasted below) i gather (-parallel port access is not allowed)
Is the root of the problem.
4th - could not find anything in bios that jumped out at me. Pci-e auto detect is on and Pci-e power conserve is turned off
those are the only 2 references to pci-e ports in bios
5th - checked hp website and it said no parallel port or driver installed. I know there is no driver for the 6i25. Is there a driver needed in debian for the pc ?
please share your thoughts and suggestions on how to proceed ???
Thank you
kent
Debug file information:
iopl() failed: Operation not permitted
cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allowed
Note: Using POSIX realtime
Failed to remap MMIO 0 of PCI device 0000:02:00.0: Operation not permitted
hm2_5i25.0: could not map in FPGA address space
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
./PDT_Laser_4_Axis_100_Watt.hal:9: waitpid failed /usr/bin/rtapi_app hm2_pci
./PDT_Laser_4_Axis_100_Watt.hal:9: /usr/bin/rtapi_app exited without becoming ready
./PDT_Laser_4_Axis_100_Watt.hal:9: insmod for hm2_pci failed, returned -1
2862
Stopping realtime threads
Unloading hal components
Thank you
kent
2862
Last edit: 21 Feb 2025 21:51 by mmt. Reason: added more
- Thank you received: 5334
21 Feb 2025 21:59 - 21 Feb 2025 22:16 #322236
Replied by PCW on topic Firmware issue with 6i25
Looks like a LinuxCNC build issue:
Also Mesaflash will fail if you use --device 6i25 since the 6I25 card has 5I25 firmware installed.
Last edit: 21 Feb 2025 22:16 by PCW.
- Thank you received: 7490
21 Feb 2025 21:59 #322237
Replied by tommylight on topic Firmware issue with 6i25
-Disable secure boot in BIOS
-do not choose parallel port in the wizard
-might not need firmware at all, depends on use case and what is already in the card, check using mesaflash
-ignore the wizard complaining about Mesa firmware, only needed for older Mesa cards
- mmt
21 Feb 2025 22:29 #322239
by mmt
Replied by mmt on topic Firmware issue with 6i25
Thank you gentleman i disabled the secure boot also enabled legacy support not sure which it was but its working now.
One more question
with this 7i76 i need 4 axis and i want to use the (5th axis or what is normally) for a second stepgen. Which if any firmware do i need to flash ?
One more question
21 Feb 2025 22:39 #322240
7i76 has 5 step/dir outputs that you can use any way you need/like (it can do 5 more so total of 10 with an added BOB or 7i75 or another 7i76).
Is that for a tandem axis ( 1 axis with 2 motors and 2 drives) ?
The wizard can deal with that also, just choose a tandem X axis or tandem Y axis or whatever you need.
- mmt
21 Feb 2025 22:54 #322244
by mmt
sorry my mistake i will post correct question below.
with this 7i76 i need 4 axis (for 4 motors) and i want to use the (what is normally the 5th axis) for a PWMGEN. Which if any firmware do i need to flash ?
this is to send pwm to a dac for one of my equipment features as i am already using the spindle output
22 Feb 2025 00:13 #322246
5i25_7i76x2_2pd.bit
Time to create page: 0.218 seconds
