7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
- Nathan40
24 Feb 2025 14:45 #322491
by Nathan40
Please can anyone share 7i95t pin and firmware files with Stepgens on 1,2,3,4,5,6,7,8,9,14,16,17 and Inputs on pin 10, 11,12,13,15 pins on 5Axis BOB.
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB was created by Nathan40
- Thank you received: 5326
24 Feb 2025 15:53 #322498
Replied by PCW on topic 7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
7I95T firmware for 5ABOB but with added stepgen on pins 1,14
(so 12 total)
(so 12 total)
- Nathan40
24 Feb 2025 16:14 #322501
by Nathan40
Replied by Nathan40 on topic 7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Thanks for your file. Please confirm if it contains the input pins information for 5 Axis BOB.
If not, please add the same.
24 Feb 2025 16:58 #322506
Its is exactly the 5ABOB config for the Sainsmart 5 Axis BOB with an added stepgen
on DB25 pins 1 and 14 (removing the PWMgen from pin 1) all other pins are GPIO
- Sternfox
- Thank you received: 7
05 Mar 2025 14:28 #323271
by Sternfox
Replied by Sternfox on topic 7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Hi PWC will any 5-axis bob work with this firmware? The Sainsmart boards are hard to get in the UK
05 Mar 2025 16:32 #323285
Most will work for step/dir but the spindle PWM output may be on different pins
What is the pinout of a breakout available to you?
- Sternfox
05 Mar 2025 19:52 #323308
by Sternfox
I have just purchased a amazon bob. It looks similar to the one you mentioned. As far as I understand most of them have the same pins on the db25 port.
- Nathan40
07 Mar 2025 12:30 #323413
by Nathan40
a. Does these have inputs in the firmware for the 5ABoB on p10, p11, p12, p13, p15?
b. Also please guide as how I can update this new firmware on the 7i95t using Mesa CT.
Your help will be truly be appreciated.
07 Mar 2025 14:50 - 07 Mar 2025 14:51 #323415
A: All I/O pins are inputs unless selected for other use in the driver
(man hostmot2) or the hal file.
B: To program the firmware using mesaflash you would
download the firmware and then:
mesaflash --device 7i95t --addr [card_ip_address] --write 7i95t_5abobd.bin --reload
I would ask in the MesaCT section how to do this using MesaCT.
Last edit: 07 Mar 2025 14:51 by PCW.
- Nathan40
08 Mar 2025 01:44 #323481
by Nathan40
Time to create page: 0.150 seconds
