7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
24 Feb 2025 14:45 #322491 by Nathan40
Please can anyone share 7i95t pin and firmware files with Stepgens on 1,2,3,4,5,6,7,8,9,14,16,17 and Inputs on pin 10, 11,12,13,15 pins on 5Axis BOB.
24 Feb 2025 15:53 #322498 by PCW
7I95T firmware for 5ABOB but with added stepgen on pins 1,14
(so 12 total)
File Name: 7i95t_6ppst.zip
File Size:307 KB
24 Feb 2025 16:14 #322501 by Nathan40
Thanks for your file. Please confirm if it contains the input pins information for 5 Axis BOB.
If not, please add the same.
24 Feb 2025 16:58 #322506 by PCW
Its is exactly the 5ABOB config for the Sainsmart 5 Axis BOB with an added stepgen
on DB25 pins 1 and 14 (removing the PWMgen from pin 1) all other pins are GPIO
05 Mar 2025 14:28 #323271 by Sternfox
Hi PWC will any 5-axis bob work with this firmware? The Sainsmart boards are hard to get in the UK
05 Mar 2025 16:32 #323285 by PCW
Most will work for step/dir but the spindle PWM output may be on different pins
What is the pinout of a breakout available to you?
05 Mar 2025 19:52 #323308 by Sternfox
I have just purchased a amazon bob. It looks similar to the one you mentioned. As far as I understand most of them have the same pins on the db25 port.
07 Mar 2025 12:30 #323413 by Nathan40
a. Does these have inputs in the firmware for the 5ABoB on p10, p11, p12, p13, p15?
b. Also please guide as how I can update this new firmware on the 7i95t using Mesa CT.
Your help will be truly be appreciated.
07 Mar 2025 14:50 - 07 Mar 2025 14:51 #323415 by PCW
A: All I/O pins are inputs unless selected for other use in the driver
(man hostmot2) or the hal file.
B: To program the firmware using mesaflash you would
download the firmware and then:
mesaflash --device 7i95t --addr [card_ip_address] --write 7i95t_5abobd.bin --reload
I would ask in the MesaCT section how to do this using MesaCT.
Last edit: 07 Mar 2025 14:51 by PCW.
08 Mar 2025 01:44 #323481 by Nathan40
Moderators: PCW, jmelson
