7i95 randomly throws error with raspi b
- Nathan40
12 Mar 2025 23:53 #323784
by Nathan40
7i95 randomly throws error with raspi b was created by Nathan40
Hi all
after working for 1 hour without any issue the 7i95t randomly resets with error in raspi b 8gb. I have a dedicated heat sink with fans on the raspi b. I am using latest linuxcnc 2.9 image for raspi b given on the website. Please let me know the reason if anyone has faced a similar problem
- Thank you received: 7478
12 Mar 2025 23:55 #323785
Replied by tommylight on topic 7i95 randomly throws error with raspi b
What error?
- Thank you received: 5326
12 Mar 2025 23:59 #323786
Replied by PCW on topic 7i95 randomly throws error with raspi b
If the 7I95T actually resets, that's a power supply issue.
The following user(s) said Thank You: unknown
- unknown
- Thank you received: 323
13 Mar 2025 04:36 #323798
by unknown
Replied by unknown on topic 7i95 randomly throws error with raspi b
To the OP just for reference next time could you specify if you are using a RPi4 or RPi5 so if we need to look at the images it makes life easier. As both the 4 & 5 come in B variants.
Cheers
Rob
Cheers
Rob
- Nathan40
14 Mar 2025 03:06 #323885
by Nathan40
Replied by Nathan40 on topic 7i95 randomly throws error with raspi b
It is a raspi 4 8 gb version. I tried with a changed power supply and after few hours it again reset. Upon pressing the reset button the axis showed no movement. However, after restarting linuxcnc it started working fine.
- unknown
14 Mar 2025 04:01 #323886
by unknown
I think PCW was referring to the power supply for the mesa card.
You may also be experiencing issues with the RPi4 ethernet powering down, this is a much talked about issue.
If you look at the RPi sticky under installing Linuxcnc the very last post discusses this issue with a link to some trouble shooting.
14 Mar 2025 14:43 #323929
I think it was the wording "reset". To actually reset a 7I95T
you need to cycle the power (or issue a reset command but
LinuxCNC never does this)
If this is a real time error, it may be that the servo thread period
needs to be increased to say 2 ms as 1 ms is marginal on a RPI4.
The following user(s) said Thank You: Nathan40
Time to create page: 0.577 seconds
