7i96 not working anymore
- persei8
- Thank you received: 133
15 Mar 2025 15:38 #324005
by persei8
7i96 not working anymore was created by persei8
After updating linuxcnc, I now get the following:Then I tried:Is the 7i96 toast, hostmot broken? All I did after a few weeks on non use was update llinuxcnc (2.10.0-pre0) I had to compile from source since buildbot is no longer working.
Jim
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:00:b6
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Low Level init 0.15
hm2/hm2_7i96.0: created PktUART Interface function hm2_7i96.0.pktuart.0.
*** buffer overflow detected ***: terminated
./qtdragon.hal:13: waitpid failed /usr/bin/rtapi_app hm2_eth
./qtdragon.hal:13: /usr/bin/rtapi_app exited without becoming ready
./qtdragon.hal:13: insmod for hm2_eth failed, returned -1
USRMOT: ERROR: command 30 timeout (seq: 1)
emcMotionInit: emcTrajInit failed
Waited 3 seconds for master. giving up.jim@Linuxcnc:~/Downloads/7i96/configs/hostmot2$ mesaflash --device 7i96
lbp16_access.send_packet: Resource temporarily unavailable
AbortedJim
- Thank you received: 5334
15 Mar 2025 15:45 #324006
Replied by PCW on topic 7i96 not working anymore
That's a LinuxCNC error perhaps in the modbus code
After that error that you may need to run
halrun -U
or if that does not work, reboot the computer
Because LinuxCNC blocks access to the Ethernet port the 7I96 uses
Until it exits cleanly (this is likely why mesaflash does not work)
halrun -U
- persei8
15 Mar 2025 18:45 #324015
by persei8
Replied by persei8 on topic 7i96 not working anymore
Computer rebooted.
Power on the controller.
Without trying to run linuxcnc:A sim config works just fine. The problem is only with the real machine. I would try to flash it back to the original bitfile, the one without pktuart, but mesaflash doesn't seem to communicate with the 7i96.
Jim
$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.315 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.167 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.162 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.159 ms
^C
--- 10.10.10.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3061ms
rtt min/avg/max/mdev = 0.159/0.200/0.315/0.066 msjim@Linuxcnc:~$ halrun -U
Note: Using POSIX realtime
jjim@Linuxcnc:~$ mesaflash --device 7I96
Aborted
jJim
15 Mar 2025 18:51 #324017
You need to supply the card address when using mesaflash:
mesaflash --device 7i96 --addr 10.10.10.10
- persei8
15 Mar 2025 22:03 #324029
by persei8
Well it's working again. I reflashed the card to the standard bitfile. Apparently, whatever changed in hostmot didn't like the pktuart config. Thanks for your help.
Jim
Jim
Time to create page: 0.079 seconds
