e-stop signal from hybrid servo stepper threw Mesa 7i96s
23 Mar 2025 10:40 #324640 by kmeld
I do not actually know where to start.
I have 3axis cnc mill set up on Mesa 7i96s with hybrid servo stepper drives 2HSS86H-N
currently when stepper drive goes in to error (position following error) motor stops and is not responding but while cnc control does not go in to e-stop mode.
I would like to have it set up in such a way so in such event as one of the controllers goes in to any fault it will automatically trigger e-stop for the whole control.
Could someone help me set this up?
I need help on very basic level in this field.
Cris.
  • Moderator
  • Moderator
23 Mar 2025 11:40 #324650 by tommylight
Does the drive have a fault output?
Is that fault output wired to Mesa input?
Is the Mesa input pin wired to joint.0.amp-fault in hal?
Those are the things required for a fault to stop the machine, it will not trigger e-stop but it will disable the machine completely, so after fixing whatever the issue was, you can just enable the machine and continue working.
23 Mar 2025 12:48 #324653 by rodw
As Tommy says connect the alarm output on the drive to to joint.N.amp-fault-in
You may need to invert the signal with the not component. I know I had to.
30 Mar 2025 19:30 #325342 by kmeld
Thanks,
I will look how everything is wired.
will get back if need more help
Cris.
Moderators: PCW, jmelson
Time to create page: 0.101 seconds
