7i92 firmware issue
11 Apr 2025 16:15 #326079 by unknown
7i92 firmware issue was created by unknown
Building 7i92 firmware for a custom board. I've had to play around with
Turn on board everything seems ok, user leds count packets
IP set to 192.168.1.121
Responds to pings
When jumpered for bootp an ip address is received and I can ping it.
This has me stumped 7i92 mac is ff:ff:ff:ff:ff:ff
$ mesaflash --device 7i92 --addr 192.168.1.121 --verbose
Unsupported ethernet device ��������������������z at 192.168.1.121
No 7I92 board found
��������������������z bit will change on each mesaflash run
Wireshark dump
32    7.057855358    192.168.1.20    192.168.1.121    UDP    46    50697 → 27181 Len=4
Frame 32: 46 bytes on wire (368 bits), 46 bytes captured (368 bits) on interface ens5, id 0
Ethernet II, Src: UniversalGlo_3e:7d:ac (cc:52:af:3e:7d:ac), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 192.168.1.20, Dst: 192.168.1.121
User Datagram Protocol, Src Port: 50697, Dst Port: 27181
Data (4 bytes)
    Data: 01420001
    [Length: 4]
33    7.058018908    192.168.1.121    192.168.1.20    UDP    60    27181 → 50697 Len=4
Frame 33: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface ens5, id 0
Ethernet II, Src: Broadcast (ff:ff:ff:ff:ff:ff), Dst: UniversalGlo_3e:7d:ac (cc:52:af:3e:7d:ac)
Internet Protocol Version 4, Src: 192.168.1.121, Dst: 192.168.1.20
User Datagram Protocol, Src Port: 27181, Dst Port: 50697
Data (4 bytes)
    Data: fecaaa55
    [Length: 4]
34    7.060132328    192.168.1.20    192.168.1.121    UDP    46    50697 → 27181 Len=4
Frame 34: 46 bytes on wire (368 bits), 46 bytes captured (368 bits) on interface ens5, id 0
Data (4 bytes)
    Data: 885d0000
    [Length: 4]
35    7.060285405    192.168.1.121    192.168.1.20    UDP    60    27181 → 50697 Len=16
Frame 35: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface ens5, id 0
Data (16 bytes)
    Data: ffffffffffffffffffffffffffffffff
    [Length: 16]
I'm guessing the data in the last packet isn't right.
11 Apr 2025 16:26 #326081 by PCW
Replied by PCW on topic 7i92 firmware issue
Sounds like the MAC/cardname/ipaddress/netmask EEPROM has not been programmed
11 Apr 2025 16:47 #326085 by unknown
Replied by unknown on topic 7i92 firmware issue
Ok much appreciated.
It's 2:45am I best be getting some sleep.
Guess I'll swap the eeprom.
11 Apr 2025 20:17 - 11 Apr 2025 20:27 #326106 by PCW
I'm not so much suggesting that the EEPROM is bad, but rather
that the EEPROM is empty. (never been programmed)
Last edit: 11 Apr 2025 20:27 by PCW.
11 Apr 2025 20:27 #326109 by unknown
Oh the 93c46 has to be programmed separately ?
I thought the firmware did that
11 Apr 2025 20:38 #326111 by unknown
I understand now, silly me.
Ok found I had to use setname & found the Linux version here
www.forum.linuxcnc.org/27-driver-boards/...board?start=10#65737
and I can communicate.
Thanks again
11 Apr 2025 21:09 #326113 by PCW
Here's a more complete set of utilities:
( note that you should not use Mesa's MAC in the addresses in the scripts )
freeby.mesanet.com/unixfpgainit.zip
12 Apr 2025 00:02 #326132 by unknown
Wow thanks Pete, was just thinking about how to do this. I really think I owe you a few beers.
Another question, if I may.
[/code]./setmac 00601B168$1/[code]
What's the format for the MAC ?
12 Apr 2025 00:11 #326133 by PCW
12 hex characters (this is from an initialization script so the
last three characters (the $1) are supplied on the command line
that is:
./setmac 00123456789A
etc
Note that "00601B" is Mesas range
12 Apr 2025 00:44 - 12 Apr 2025 00:57 #326134 by unknown
./newmac: line 8: ./setmac: Text file busy
Reseting Ethernet CPU
waiting for reset
./newmac: line 14: ./setmac: Text file busy
Is that a worry ? Or is that due to network latency ?
Board is behind a switch and I'm working on a laptop connect via wifi, I can ping and readhmid with mesa flash ok
I used ./setmac 00123456789A in the script
Dumb me I should have sourced the file. All is good.
Last edit: 12 Apr 2025 00:57 by unknown. Reason: I forgot how to Linux
Moderators: PCW, jmelson
Time to create page: 0.263 seconds
