7i92 firmware issue
- Thank you received: 5314
12 Apr 2025 01:02 #326135
Replied by PCW on topic 7i92 firmware issue
I think that message usually means some issue with the script
I get:
peter@peter-HP-EliteDesk-800-G1-USDT:~/Downloads$ ./getmac
Old MAC Addr: 00601B168000
peter@peter-HP-EliteDesk-800-G1-USDT:~/Downloads$ ./newmac
New MAC Addr: 00601B160801
Reseting Ethernet CPU
waiting for reset
Old MAC Addr: 00601B160801
what does
./setmac
reply
it should be
peter@peter-HP-EliteDesk-800-G1-USDT:~/Downloads$ ./setmac
Interface not in Environment
I get:
waiting for reset
what does
./setmac
reply
it should be
- unknown
- Thank you received: 325
12 Apr 2025 02:34 #326139
by unknown
Works fine.
Sometimes I just have to manually delete the ARP entry for 192.168.1.121
Testing isn't ideal ATM, ping times from the laptop to the card is bad due to having to go through 2 switches (0.244ms best). Setting the MAC works, good ole' 00:de:ad:be:ef:03 that I picked up from a netware 4 instructor.
I'll have to connect things properly & do some testing.
Once again thanks for all the help.
Replied by unknown on topic 7i92 firmware issue
./newmacWorks fine.
- unknown
12 Apr 2025 11:29 #326160
by unknown
Almost there, just having issues using mesaflash to upload a config.
Erasing goes ok, but hangs at random points when writing.
Loading drivers via halrun works as expected.
Have tried with just writing to internal FPGA config & using openFPGALoader to write to flash.
mesaflash --device 7i92 --addr 10.10.10.10 --fix-boot-block --write some_file.bit
Had no issues with the EPP board, load into fpga config then writing with mesaflash was no issue.
Is there a particular version of etherhm2 (16,17 or 18) that needs to be used ?
Due to pin allocatons I have to build my own bitfiles.
12 Apr 2025 14:09 #326166
My guess would be some Ethernet data <--> FPGA transfer issue.
Does the Ethernet chip interrupt pin (EINT) have a pullup?
Drive = 4 on ECLK (for series termination)?
The firmware version is not really important as the fixes are minor
(LED issues, Addition of netmask, addition of MAC mask)
- unknown
12 Apr 2025 23:01 #326199
by unknown
I thought EINT might be the issue, there's a 1k pullup to 3.3v, the top 8 data lines have a 1k pull down.
Might be C5 around the L1 inductor, I installed a 100nf cap instead of a 4.7uf.
I don't know if that will make a lot of difference.
I've run a config, no hardware connected to the board yet, but no errors. Tho I assume writing to the flash is more of a load. It's bound to be something stupid on my behalf.
The major difference is the WP on the flash is just held high, any chance that the circuit around the WP on the flash is causing the issue, there's no reset device connected. Tho the EPP & SPI based on the 7c81 have been the same.
14 Apr 2025 03:03 #326240
If its just a flash issue, ( normal Ethernet comms are reliable )
It may possibly be a a compatibility issue or perhaps signal
integrity or some other flash EEPROM connection issue.
- unknown
14 Apr 2025 04:41 #326242
by unknown
I think it might be a comms issue relating to the filtering issue around the internal voltage regs. All the ref designs I've seen use 4.7uf cap with the 2 100nf with the inductor. I'll have to wait for some caps to come in.
Using openFGPALoader with the flash over SPI works fine (load a config directly to the FPGA then communicates with the FPGA ), so I can reliably write to the flash.
Looking at a session with wireshark, the board stops comms first. And the time it takes to happen can be kind of random. I'm prepared to accept that the design may not just work due to "Reasons" (bad layout, signal trace lengths, lack of knowledge of my behalf). I may have to read the mesaflash code and work out the programming protocol to get a better understanding.
- unknown
15 Apr 2025 20:59 #326408
by unknown
A little update, changed the EEPROM from a 16MB ST part to a 16MB Winbond part (same as I've used for the EPP\SPI board). Initially no change.
Put a 5ms delay between before the "sync" instruction when erasing & writing a bitfile. Was able to write a bitfile, not everytime, but when it does it verifies ok.
Ran 100 iterations of the Linuxcnc logo gcode, one after another in a loop, and then left it, after 12 hours no comms issues.
15 Apr 2025 21:17 #326410
Can it verify repeatedly without error?
If so if may be something related to write
(how are the WP and HOLD pins terminated?)
- unknown
16 Apr 2025 00:52 #326417
by unknown
Ran
./mesaflash --device 7i92 --addr 10.10.10.10 --verify ~/linuxcnc/firmware/7i92/TopEthernetHostMot2.bit
about 10 times passed every time.
Just for completeness tried verifying against another bitfile (not written to flash) and failed as expected.
Hold & WP are tied directly to 3.3v CS is tied hi via 10k resistor.
If the main clk is out, part is marked as 50Mhz, could this throw a spanner in the works ? But then that would affect the Ethernet Interface's 25Mhz clock.
It feels like the write is taking longer than expected, but checking the busy flag would mitigate this. That's why I thought of putting a delay between mesaflash wiritng a page and the "packet read for board syncing"
Time to create page: 0.324 seconds
