Mesa 7i97T unresponsive analog outputs
- matasbuk
- Thank you received: 3
15 Apr 2025 18:22 #326394
by matasbuk
Mesa 7i97T unresponsive analog outputs was created by matasbuk
Hello, trying to setup the 7i97T, but output 0 always seems to be at 4.55v no matter what, its enough to power up the board and not connect it to anything. Output 3 is the same. other outputs stay at 0 and do not change through halshow then I enter value manually. Even though they are enabled and scale set. My .ini and .hal files are attached.
- Thank you received: 5334
15 Apr 2025 18:38 #326398
Replied by PCW on topic Mesa 7i97T unresponsive analog outputs
If any analog output is not close to 0V at power up, (and no output mis-connections)
there is a hardware problem (perhaps a damaged op-amp) on the card and it needs repair.
- matasbuk
15 Apr 2025 19:27 #326401
by matasbuk
Replied by matasbuk on topic Mesa 7i97T unresponsive analog outputs
Tried with everything except power disconnected, tried to connect the drive, but the drive would proper forward with no command with stable speed with LinuxCNC off. Channel 3 was never even attempted to connect. Other channels are unresponsive.
15 Apr 2025 20:43 #326407
If you have nothing connected to the 7I97T but 5V power and any analog
output is not close to 0V, the analog output circuitry has been damaged somehow.
This may occur if an output was inadvertently shorted to say +24V or
connected before a common ground was established between the drive and
the 7I97T.
the 7I97T.
Time to create page: 0.167 seconds
