7i80db 7i77 + 7i76 serup Hal conf
- GDTH
19 Apr 2025 11:31 #326684
by GDTH
7i80db 7i77 + 7i76 serup Hal conf was created by GDTH
Hello,
I am trying to get a 7i80db-25 working with a 7i77 and a 7i76. I have installed a bitfile that should make this possible. When I start up linuxcnc I am not able to find the 7i77 and 7i76 board in the Hal conf. I was expecting something like hm2_7i80.0.7i77.input.
Am I doing something wrong or is it normal to just have a gpio list. If so how do I know what is connected to what.
- Thank you received: 7490
19 Apr 2025 11:35 #326685
Replied by tommylight on topic 7i80db 7i77 + 7i76 serup Hal conf
What does
mesaflash --device ETHER --readhmid
report?
report?
- GDTH
19 Apr 2025 11:39 #326686
by GDTH
Replied by GDTH on topic 7i80db 7i77 + 7i76 serup Hal conf
mesaflash --device ETHER --readhmid --addr 192.168.1.121 gives:
Configuration Name: HOSTMOT2
BoardName : MESA7I80
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 4
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 4 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 16 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3500
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: StepGen
There are 16 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: SSerial
There are 2 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5A00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for J2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData0 (Out)
8 11 IOPort SSerial 0 RXData0 (In)
9 12 IOPort SSerial 0 TXData1 (Out)
10 13 IOPort SSerial 0 RXData1 (In)
11 14 IOPort MuxedQCount 6 MuxQ-IDX (In)
12 15 IOPort MuxedQCount 6 MuxQ-B (In)
13 16 IOPort MuxedQCount 6 MuxQ-A (In)
IO Connections for J3
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData2 (Out)
8 28 IOPort SSerial 0 RXData2 (In)
9 29 IOPort SSerial 0 TXData3 (Out)
10 30 IOPort SSerial 0 RXData3 (In)
11 31 IOPort MuxedQCount 7 MuxQ-IDX (In)
12 32 IOPort MuxedQCount 7 MuxQ-B (In)
13 33 IOPort MuxedQCount 7 MuxQ-A (In)
IO Connections for J4
1 34 IOPort SSerial 1 TXEn2 (Out)
14 35 IOPort SSerial 1 TXData2 (Out)
2 36 IOPort SSerial 1 RXData2 (In)
15 37 IOPort SSerial 1 TXData1 (Out)
3 38 IOPort SSerial 1 RXData1 (In)
16 39 IOPort SSerial 1 TXData0 (Out)
4 40 IOPort SSerial 1 RXData0 (In)
17 41 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 42 IOPort MuxedQCount 0 MuxQ-A (In)
6 43 IOPort MuxedQCount 0 MuxQ-B (In)
7 44 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 45 IOPort MuxedQCount 1 MuxQ-A (In)
9 46 IOPort MuxedQCount 1 MuxQ-B (In)
10 47 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 48 IOPort MuxedQCount 2 MuxQ-A (In)
12 49 IOPort MuxedQCount 2 MuxQ-B (In)
13 50 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for J5
1 51 IOPort SSerial 1 TXEn5 (Out)
14 52 IOPort SSerial 1 TXData5 (Out)
2 53 IOPort SSerial 1 RXData5 (In)
15 54 IOPort SSerial 1 TXData4 (Out)
3 55 IOPort SSerial 1 RXData4 (In)
16 56 IOPort SSerial 1 TXData3 (Out)
4 57 IOPort SSerial 1 RXData3 (In)
17 58 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 59 IOPort MuxedQCount 3 MuxQ-A (In)
6 60 IOPort MuxedQCount 3 MuxQ-B (In)
7 61 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 62 IOPort MuxedQCount 4 MuxQ-A (In)
9 63 IOPort MuxedQCount 4 MuxQ-B (In)
10 64 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 65 IOPort MuxedQCount 5 MuxQ-A (In)
12 66 IOPort MuxedQCount 5 MuxQ-B (In)
13 67 IOPort MuxedQCount 5 MuxQ-IDX (In)
19 Apr 2025 11:42 #326688
OK,
Mesa 7i76 to connector J2
Mesa 7i77 to connector J4
- GDTH
19 Apr 2025 11:44 #326689
by GDTH
i already have that.
Or able to see that from the data?
19 Apr 2025 11:48 #326691
Do they show in "show hal configuration" from the "machine" menu?
- GDTH
19 Apr 2025 11:48 #326692
by GDTH
in case the hal and ini files are needed
- GDTH
19 Apr 2025 11:52 #326693
by GDTH
do you mean this?
19 Apr 2025 11:52 #326694
Try setting all sserial to 000000 instead of 000xxx in the loadrt line, to many sserials enabled in the firmware so might be disabled with x.
- GDTH
19 Apr 2025 11:54 #326695
by GDTH
just did that, made no difference to how to hal conf looks like :?
Time to create page: 0.111 seconds
