amplifier fault troubleshooting
22 Apr 2025 22:44 #326925 by PCW
Replied by PCW on topic amplifier fault troubleshooting
if you measure across A+ , A- you should get alternating polarities like your +3.5V, -3.5V
If you measure A+, A- relative to ground they should be close to ground in one state
and > 2.4V in the other.
23 Apr 2025 01:30 #326926 by bentiggin
Replied by bentiggin on topic amplifier fault troubleshooting
Ah, thanks for setting me straight.
Since I'm getting encoder signals to the 7i97t, but it's not getting that signal to linuxcnc, than I assume that the high frequency start somehow damaged it.
23 Apr 2025 02:38 - 23 Apr 2025 02:39 #326927 by PCW
The 7I97T is likely repairable if only the encoder interface chip(s) are damaged.
You might check if any encoder inputs work.
Last edit: 23 Apr 2025 02:39 by PCW.
23 Apr 2025 05:13 #326932 by rodw
Replied by rodw on topic amplifier fault troubleshooting
This:
net plasmac:breakaway joint.0.amp-fault-in <= hm2_7i97.0.inmux.00.input-04-not
Looks like the only thing that can generate a amplifier fault
Why would you connect the torch breakaway switch to an amplifier fault? That is wrong
Moderators: PCW, jmelson
