- Thank you received: 12
Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
- Adam Maszynotwór
- Topic Author
1 year 6 months ago #327505
by Adam Maszynotwór
Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error was created by Adam Maszynotwór
ProblemAs a newbie to Mesa cards, I spent a whole night trying to connect to a 7I76EU card (IP 10.10.10.10, jumpers W2=OFF, W3=OFF). mesaflash kept throwing errors: „Unsupported ethernet device 7I76EU” or „No 7I76EU board found”, even though ping to 10.10.10.10 worked and LEDs CR4 (FIELD POWER) and CR14 (LOGIC POWER) were on. CR11 (FIELD I/O FAULT) was lit, and CR13 (FPGA /DONE) sometimes lit up, hinting at a firmware issue. I wasn’t sure whether to use 7I76EU or 7I76E in commands, as 7I76EU is less common.What I checked
Show in sidebar
- Power: Connected 24V DC to TB1 (VIN) and TB2 (FIELD POWER), following: YouTube: Mesa 7I76E Power . Jumper W1=ON. Did not use P4/P5 (5V) as the card has built-in regulators.
- Network: Used a standard Ethernet cable (non-crossover), connected directly to PC. Initially tried IP 192.168.1.121 (W2=ON, W3=OFF), but switched to 10.10.10.10 (W2=OFF, W3=OFF), setting up the network per: Forum: Mesa Ethernet Setup . PC IP was 10.10.10.11/24, firewall disabled (sudo ufw disable).
- mesaflash attempts: Commands like sudo mesaflash --device 7i76eu --addr 10.10.10.10 --readhmid failed. I noticed the error mentioned „7I76EU” even when I used ETHER or 7i76e, suggesting the card was detected but not supported by mesaflash.
- LinuxCNC: Using Pncconf, I configured for 7I76E (IP 10.10.10.10). Changing INI to BOARD=7I76EU caused LinuxCNC to fail, but BOARD=7I76E worked, and CR11 turned off. On TB2, a multimeter showed DIR+5V signals changing with axis movement, and shorting IN17 to +24V activated the input in HAL. The card was working!
- Check version:
bash
CopyMy version was too old.Code:mesaflash --version - Install dependencies (Debian Bookworm):
bash
CopyCode:sudo apt update sudo apt install libpci-dev libmd-dev pkg-config build-essential git - Download and compile mesaflash:
bash
CopyCode:git clone https://github.com/LinuxCNC/mesaflash.git cd mesaflash make sudo make install - Verify version:
bash
CopyShowed: 3.5.13.Code:mesaflash --version - Test communication:
bash
CopyAfter fixing a cable mix-up, it returned card details: BoardName: MESA7I76, HostMot2 firmware, 5 StepGen, 3 I/O ports.Code:mesaflash --addr 10.10.10.10 --device ETHER --readhmid
- Ensure the PC is in the 10.10.10.x/24 subnet and firewall is disabled.
- Jumpers W2=OFF, W3=OFF set IP 10.10.10.10; W2=ON, W3=OFF sets 192.168.1.121.
- LinuxCNC with BOARD=7I76E works because 7I76EU is compatible with 7I76E in older versions.
- CR13 (FPGA /DONE) stopped lighting up after LinuxCNC started correctly, but updating mesaflash was key for proper diagnostics.
Show in sidebar
The following user(s) said Thank You: tommylight, jackj120, degger
1 year 6 months ago #327513
Replied by tommylight on topic Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Was this with the version included in the 2.9.4 ISO?
Djakuju bardzo.
Djakuju bardzo.
- Thank you received: 4820
1 year 6 months ago #327514
Replied by PCW on topic Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Yes, a fairly ancient version of mesaflash (3.4.9) is included with the
LinuxCNC 2.9.4 ISO, this is supposedly fixed for later releases.
- Adam Maszynotwór
- Topic Author
1 year 6 months ago #327519
by Adam Maszynotwór
Replied by Adam Maszynotwór on topic Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Yes. Current stable version 2.9.4 ISO
I think that mesa and linuxcnc card experts may not have even noticed this. because they either knew where and how to download the updates without a problem. or they skipped this step altogether and did the configuration right away.
1 year 6 months ago #327520
Yes, in most cases, mesaflash is not needed as the installed firmware is sufficient.
1 year 6 months ago #327558
If that is the case, 2.9.4 will just get the very early version in the Bookworm repo.
Perhaps Our Debian build system should be modified to make mesaflash so it gets stored in our repos
Replied by rodw on topic Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
I don't think mesaflash is included in V 2.9.4 in our ISOs because it is seperate to Linuxcnc and has its own Deb file.Yes, a fairly ancient version of mesaflash (3.4.9) is included with the
- Ingo
9 months 1 week ago #341816
by Ingo
Replied by Ingo on topic Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
I'm having the exact same problem, has anyone figured out what's going on?
Tks
Tks
9 months 1 week ago - 9 months 1 week ago #341819
If mesaflash reported that error, update mesaflash
(instructions on the git site or above in this thread)
If LinuxCNC reported the issue, you need t o update LinuxCNC.
(You don't actually have to update LinuxCNC as it will work fine but will complain about the card every time you start LinuxCNC)
Last edit: 9 months 1 week ago by PCW.
- Pupy1993
8 months 2 weeks ago #342974
by Pupy1993
Replied by Pupy1993 on topic Mesa 7I76EU – Fixing „Unsupported ethernet device – No 7I76EU board found” Error
Hello.
I'm new in this form. I couldn't config my Mesa Card 7i76EU, the PncConf doesn't show the 7i76eu. I'm using Linux CNC 2.9.8. Thanks in advance.
8 months 2 weeks ago #342978
The 7I76EU is compatible with 7I76E hal/ini files, so you can
just select "7I76E" in pncconf.
Time to create page: 0.079 seconds
