ProblemAs a newbie to Mesa cards, I spent a whole night trying to connect to a
7I76EU card (IP 10.10.10.10, jumpers W2=OFF, W3=OFF). mesaflash kept throwing errors:
„Unsupported ethernet device 7I76EU” or
„No 7I76EU board found”, even though ping to 10.10.10.10 worked and LEDs CR4 (FIELD POWER) and CR14 (LOGIC POWER) were on. CR11 (FIELD I/O FAULT) was lit, and CR13 (FPGA /DONE) sometimes lit up, hinting at a firmware issue. I wasn’t sure whether to use 7I76EU or 7I76E in commands, as 7I76EU is less common.What I checked
- Power: Connected 24V DC to TB1 (VIN) and TB2 (FIELD POWER), following:
YouTube: Mesa 7I76E Power
. Jumper W1=ON. Did not use P4/P5 (5V) as the card has built-in regulators.
- Network: Used a standard Ethernet cable (non-crossover), connected directly to PC. Initially tried IP 192.168.1.121 (W2=ON, W3=OFF), but switched to 10.10.10.10 (W2=OFF, W3=OFF), setting up the network per:
Forum: Mesa Ethernet Setup
. PC IP was 10.10.10.11/24, firewall disabled (sudo ufw disable).
- mesaflash attempts: Commands like sudo mesaflash --device 7i76eu --addr 10.10.10.10 --readhmid failed. I noticed the error mentioned „7I76EU” even when I used ETHER or 7i76e, suggesting the card was detected but not supported by mesaflash.
- LinuxCNC: Using Pncconf, I configured for 7I76E (IP 10.10.10.10). Changing INI to BOARD=7I76EU caused LinuxCNC to fail, but BOARD=7I76E worked, and CR11 turned off. On TB2, a multimeter showed DIR+5V signals changing with axis movement, and shorting IN17 to +24V activated the input in HAL. The card was working!
SolutionThe issue was an outdated mesaflash version that didn’t support 7I76EU. Updating from GitHub fixed it. Steps:
- Check version:
bash
Copy
mesaflash --version
My version was too old.
- Install dependencies (Debian Bookworm):
bash
Copy
sudo apt update sudo apt install libpci-dev libmd-dev pkg-config build-essential git
- Download and compile mesaflash:
bash
Copy
git clone https://github.com/LinuxCNC/mesaflash.git cd mesaflash make sudo make install
- Verify version:
bash
Copy
mesaflash --version
Showed: 3.5.13.
- Test communication:
bash
Copy
mesaflash --addr 10.10.10.10 --device ETHER --readhmid
After fixing a cable mix-up, it returned card details: BoardName: MESA7I76, HostMot2 firmware, 5 StepGen, 3 I/O ports.
Notes
- Ensure the PC is in the 10.10.10.x/24 subnet and firewall is disabled.
- Jumpers W2=OFF, W3=OFF set IP 10.10.10.10; W2=ON, W3=OFF sets 192.168.1.121.
- LinuxCNC with BOARD=7I76E works because 7I76EU is compatible with 7I76E in older versions.
- CR13 (FPGA /DONE) stopped lighting up after LinuxCNC started correctly, but updating mesaflash was key for proper diagnostics.
ThanksThanks to advice from
LinuxCNC.org
, YouTube videos, and Grok’s guidance, I solved the issue. Hope this helps other beginners!
Show in sidebar
