MESA 7i76E burning out issue
25 May 2025 09:40 #329099 by knipknap
Replied by knipknap on topic MESA 7i76E burning out issue
So, change made, AC power component is gone and first small test job ran successfully. Hoping for the best :-). Thank you again!
20 Jun 2025 11:09 #330567 by knipknap
I finally found the real cause.
Today i got the amplifier fault on another joint (joint 0) and I found that it the problem happened whenever I turned on the spindle.
After several attempts to measure the ground connections the machine stopped in a position where I found the machine frame was not grounded.
The reason: The spindle connector got loose. The machine frame was grounded through the spindle cable, and that cable had become loose.
All I had to do was tighten the screw of the connector. Ground connection works reliably again and the machine runs well. Phew.
Moderators: PCW, jmelson
Time to create page: 0.094 seconds
