7i97T+7i74+7i84+7i73
  • MRTtechnology
  • MRTtechnology's Avatar Topic Author
  • New Member
  • New Member
27 May 2025 14:21 #329222 by MRTtechnology
7i97T+7i74+7i84+7i73 was created by MRTtechnology
Hi guys
I'm a beginner with Mesa electronic boards and I'm retrofitting a Realmeca T200 cnc lathe ( analogs drivers ).
The configuration I'm implementing is 7i97T+ 7i74+ 7i84+ 7i73 with the bin file 7i97T&7i74d
I have a PWM version error, and I need to find the latest version of the bin file 7i97T&7i74d
Can anyone help me?
  • Moderator
  • Moderator
27 May 2025 16:03 #329234 by tommylight
Replied by tommylight on topic 7i97T+7i74+7i84+7i73
Moved to "driver boards".
While waiting, you can use 7i84 OR 7i73 with 7i97T for testing or anything, without the 7i74, meaning only one at a time.
27 May 2025 17:00 #329241 by PCW
Replied by PCW on topic 7i97T+7i74+7i84+7i73
Here is a PWM version 1 of 7i97t_7i74d.bin
File Name: 7i97t_7i74d.zip
File Size:300 KB
(Version 0 PWM will work but lacks the dither option)
  • MRTtechnology
  • New Member
  • New Member
27 May 2025 17:33 #329244 by MRTtechnology
Replied by MRTtechnology on topic 7i97T+7i74+7i84+7i73
thank you PCW I'll try it out
  • MRTtechnology
  • New Member
  • New Member
27 May 2025 17:56 #329247 by MRTtechnology
with this firware which version of linuxcnc works. does it work on raspberry PI?
Estou a usar linuxcnc 2.9.1 e Raspberry Pi 4 8g
27 May 2025 18:22 #329252 by PCW
The firmware doesn't care about the host CPU
2.9.1 is pretty old (about 1.5 years)
Not sure if 2.9.1 supports PWM dither (V1 PWMgen)
as dither was added in Oct 2023 and 2.9.1 was released
in Nov 2023.
Options:
Update LinuxCNC to current (2.9.4) or use the firmware with V0 PWMgen
  • MRTtechnology
  • New Member
  • New Member
28 May 2025 15:11 #329320 by MRTtechnology
hi guys i managed to get the communication between Rp1 7i97t+7i744+7i84+7i73 working
Thank you for your help.
  • MRTtechnology
  • New Member
  • New Member
28 May 2025 15:19 #329321 by MRTtechnology
My test bench
I know it's nothing to you experts, but for me it's a big step.
  • Moderator
  • Moderator
28 May 2025 15:35 #329322 by tommylight
As Darth Vader once said: welcome to the dark side! :)
  • MRTtechnology
  • New Member
  • New Member
28 May 2025 18:24 #329326 by MRTtechnology
Hi guys
I want to connect two MPGs to the encoder inputs of the 7i73
My MPG has A+A-B+B- OV5V e and use two analogue inputs.
To do this, I'll have to use mode 1 on the 7i73 board
Has anyone configured this board in encoder+analogue mode?
Moderators: PCW, jmelson
Time to create page: 0.783 seconds
