- Hardware & Machines
- Driver Boards
- MESA 7i92TH to power an OmioCNC 3040 LPT system ; which firmware ?
- javanree
05 Jun 2025 11:41 #329735
by javanree
MESA 7i92TH to power an OmioCNC 3040 LPT system ; which firmware ? was created by javanree
I'm trying to convert my cheap 3040 router with an LPT card to connect to LinuxCNC using a Mesa 7i92TH
Current LPT pinout is :
1 VFD spindle on (CW) , using a small relay
2 X step
3 X dir
4 Y step
5 Y dir
6 Z step
7 Z dir
11 X home in
12 Y home in
13 Z home in
15 probe in
17 VFD spindle PWM (0-2000Hz)
If I read the documentation ( 7i92tman.pdf ) correct the PROB_RFX2D would match it almost perfect , but that file is not in the ti92t.zip from the Mesa website. Which firmware am I best off to use ?
2 X step
3 X dir
4 Y step
5 Y dir
6 Z step
7 Z dir
11 X home in
12 Y home in
13 Z home in
15 probe in
- Thank you received: 5334
05 Jun 2025 14:54 #329743
Replied by PCW on topic MESA 7i92TH to power an OmioCNC 3040 LPT system ; which firmware ?
Is this PWM (for a PWM --> analog converter)
or a rate (0 to 2000Hz frequency output)
- javanree
05 Jun 2025 15:05 - 05 Jun 2025 15:08 #329746
by javanree
Replied by javanree on topic MESA 7i92TH to power an OmioCNC 3040 LPT system ; which firmware ?
PWM going into an analog converter indeed
Current config is like this
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 2000.0
setp pwmgen.0.scale 22800.0
setp pwmgen.0.offset -0.0710526315789
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-cw <= spindle.0.forward
Last edit: 05 Jun 2025 15:08 by javanree.
05 Jun 2025 16:05 #329753
This Benezan config looks correct:
Benezan breakouts have step/dir swapped but this version has
the ability to swap the default step/dir pins with a hal parameter
- Driver Boards
Time to create page: 0.106 seconds
