Flyback diode mesa 7i95t
- Thank you received: 7490
06 Jun 2025 23:32 #329849
Replied by tommylight on topic Flyback diode mesa 7i95t
+1... it aggravates me when I see opto circuits with the input and output sides connected to a common ground.
- unknown
- Thank you received: 323
09 Jun 2025 03:22 #329989
by unknown
Replied by unknown on topic Flyback diode mesa 7i95t
Using the 12v rail from your PC negates the protection the optos are used for.
I suggest to forget all the BS you've learnt from the Hipster Maker crowd and read & learn by someone that knows his stuff.
This is a good start, written by the guy that designed the TEC-1 sbc back in '83 or '84:
www.talkingelectronics.com/te_interactive_index.html
- unknown
09 Jun 2025 19:37 #330041
by unknown
The function of an optocoupler is to completely isolate one side of a circuit from another. Hence the large no copper regions under the device.
No amount of filtering, hoping nor thinking will provide this if the same supply is used or if 2 different supplied are used and their grounds connected.
Pickup a book, read & learn.
Eventually your mis advice will end with someone with less knowledge and experience than yourself having a bad time.
Those unseen electrons moving around can bite.
- unknown
10 Jun 2025 14:09 #330084
by unknown
Connecting the wires "far from each other" from the same supply will do nothing.There is no electrical isolation. None whatsoever.
10 Jun 2025 14:29 #330086
More antennae to collect interference ...
OK for stuff with no big inductive loads, not OK otherwise to use long cables, neither is using more cables.
And mind the wiring loops.
The OP seems to have left the building due to bickering and useless replies, not nice.
- unknown
10 Jun 2025 23:38 #330111
by unknown
Is it really bickering when correcting so much bad information from langdons ?
This is what I meant in my problem thread.
Apologies to the OP, just didn't want you to do anything that could cause issues.
