Flyback diode mesa 7i95t
1 year 4 months ago - 1 year 4 months ago #329838 by PCW
Replied by PCW on topic Flyback diode mesa 7i95t
Then you need arc suppressors across the relay contacts.
Possibly something like this:
www.digikey.com/en/products/detail/bourn...OV-10D201KTR/2408223
Note that it looks like the relays have their own drivers, so the 7I95T does not need
any flyback diodes.
Last edit: 1 year 4 months ago by PCW.
The following user(s) said Thank You: Sternfox
1 year 4 months ago #329843 by PCW
The issue here is that the relays are switching a 120VAC solenoid.
Because the solenoid is an inductive load, this will cause massive EMI unless
there is contact arc suppression across the relay contacts. This can be done
with a bipolar TVS diode, a MOV or an RC arc suppressor.
1 year 4 months ago #329844 by unknown
Replied by unknown on topic Flyback diode mesa 7i95t
Some do some don't, you'll need to check the data sheets.
The role of the diode is to protect the driving circuit from the reverse voltage generated from the collapse of the magnetic coil. No flyback will eventually cause component failure, a far bigger issue than EMI.
I'd take PCW's advice.
Another thing I would look at is the routing of your wiring and ensuring physical seperation of control and AC, if you haven't already taken care of this issue.
If you do use optos make sure that the input side and output side are powered by seperate PSUs and the ground are not connected, it aggravates me when I see opto circuits with the input and output sides connected to a common ground.
  • Moderator
  • Moderator
1 year 4 months ago #329848 by tommylight
Replied by tommylight on topic Flyback diode mesa 7i95t
A really big relay should not need arc suppression.
Please do some research before making such statements, especially after it has been answered by a VERY experienced member of this forum.
And who asked about MosFET's ?
  • Moderator
  • Moderator
1 year 4 months ago #329849 by tommylight
... it aggravates me when I see opto circuits with the input and output sides connected to a common ground.
+1
1 year 4 months ago #329989 by unknown
Using the 12v rail from your PC negates the protection the optos are used for.
I suggest to forget all the BS you've learnt from the Hipster Maker crowd and read & learn by someone that knows his stuff.
This is a good start, written by the guy that designed the TEC-1 sbc back in '83 or '84:
www.talkingelectronics.com/te_interactive_index.html
Moderators: PCW, jmelson
Time to create page: 1.139 seconds
