I/O ports at e000 [disabled] [size=8]
- rick-linuxcnc
12 Jun 2025 19:27 #330226
by rick-linuxcnc
I/O ports at e000 [disabled] [size=8] was created by rick-linuxcnc
I am trying to upgrade linuxcnc to 2.9.3 I was running 2.7.x I am using all the same hardware but when the parallel port tries to load it gets the I/O ports at e000 [disabled] error. On the old version is was running a port 0xe000 and irq 3
cat /proc/interrupts
CPU0 CPU1 CPU2 CPU3
0: 9 0 0 0 IO-APIC 2-edge timer
1: 0 0 0 4 IO-APIC 1-edge i8042
3: 0 0 0 0 IO-APIC 3-edge parport0
8: 1 0 0 0 IO-APIC 8-edge rtc0
sudo modinfo parport_pc
filename: /lib/modules/6.1.0-23-rt-amd64/kernel/drivers/parport/parport_pc.ko
license: GPL
description: PC-style parallel port driver
sudo dmesg | grep par
[ 8.549490] ppdev: user-space parallel port driver
[ 8.761564] parport_pc: unknown parameter 'auto' ignored
[ 8.761730] parport 0xe000 (WARNING): CTR: wrote 0x0c, read 0xff
[ 8.761736] parport 0xe000 (WARNING): DATA: wrote 0xaa, read 0xff
[ 8.761736] parport 0xe000: You gave this address, but there is probably no parallel port there!
[ 8.761750] parport0: PC-style at 0xe000, irq 3 [PCSPP,TRISTATE]
[ 8.860174] lp0: using parport0 (interrupt-driven).
lspci -vv
05:00.0 Parallel controller: Nanjing Qinheng Microelectronics Co., Ltd. CH351 PCIe Parallel Port Adapter (rev 0f) (prog-if 01 [BiDir])
Subsystem: Nanjing Qinheng Microelectronics Co., Ltd. CH351 PCIe Parallel Port Adapter
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 3
Region 0: I/O ports at e010 [disabled]
Region 1: I/O ports at e000 [disabled]
CPU0 CPU1 CPU2 CPU3
license: GPL
lspci -vv
- Thank you received: 7490
12 Jun 2025 21:13 #330231
Replied by tommylight on topic I/O ports at e000 [disabled] [size=8]
What error does LinuxCNC show?
- rick-linuxcnc
12 Jun 2025 22:52 #330236
by rick-linuxcnc
Replied by rick-linuxcnc on topic I/O ports at e000 [disabled] [size=8]
parport_pc.so file missing
- unknown
- Thank you received: 323
13 Jun 2025 14:01 #330252
by unknown
Replied by unknown on topic I/O ports at e000 [disabled] [size=8]
That file is the Linuxcnc driver, if that is missing there is something wrong with installation.
- jmelson
- Thank you received: 126
13 Jun 2025 14:46 #330253
by jmelson
The [disabled] indication means that the port will not work, the kernel has done something to disable access to it.
I had this issue with a specific Dell desktop machine, and had to use a different PCIe parport card. I recommend cards with the NetMos 9900 or 9901 chip for use on PCIe slots. These have always worked well for me.
Jon
Replied by jmelson on topic I/O ports at e000 [disabled] [size=8]
Is this the same computer that was used before? How about the parallel port card?
I am trying to upgrade linuxcnc to 2.9.3 I was running 2.7.x I am using all the same hardware but when the parallel port tries to load it gets the I/O ports at e000 [disabled] =8error. On the old version is was running a port 0xe000 and irq 3
lspci -vv
Jon
- rick-linuxcnc
26 Jun 2025 17:06 #330899
by rick-linuxcnc
got a new card didn/t help. same messages. I finally just install version 2.9.4 and everything works.
- jmelson
26 Jun 2025 21:42 #330908
by jmelson
Very interesting! Can you report what kernel is installed on your 2.9.4 system?
The command is uname -a
(I'm guessing you can't do this for the 2.9.3 system as you have probably overwritten that hard drive.)
Well, I am very happy that this ports [disabled] mess is fixed by a newer kernel!
Thanks,
Jon
Thanks,
Jon
- rick-linuxcnc
14 Jul 2025 20:59 #331833
by rick-linuxcnc
the report from uname -a is
Linux Linuxcnc 6.1.0-30-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12) x86_64 GNU/Linux
Time to create page: 0.165 seconds
