override pots or encoders
- vre
- Thank you received: 17
17 Jun 2025 08:53 #330382
by vre
override pots or encoders was created by vre
I want to add 4 override pots-encoders to linuxcnc.
Feed-rapid-spindle-jog override because qtdragon sliders from touch screen are not easy usable.
How can I do it this.
Arduino and potentiometers? Other way?
- meister
- Thank you received: 502
17 Jun 2025 09:33 #330384
by meister
Replied by meister on topic override pots or encoders
would definitely use encoder if you want to change the values from different places
i think arduino-connector can do that.
or the luxury version
www.youtube.com/shorts/jnna9jJnXfs
- Thank you received: 5334
17 Jun 2025 20:41 #330415
Replied by PCW on topic override pots or encoders
If you have a Mesa setup, you could add a 7I73 that will support up to 4
MPG encoders (plus buttons/keypad/etc) and unlike the Arduino, it's
real-time.
real-time.
- jmelson
- Thank you received: 126
17 Jun 2025 21:27 #330418
by jmelson
Replied by jmelson on topic override pots or encoders
I have a jog pendant with an MPG. A selector switch tells LCNC what the MPG is supposed to adjust, I have regular axes, feed override and spindle override set up there.
See : pico-systems.com/pendant.html
for more info, schematics, etc.
This is used with my Pico Systems interface boards, but should be easy to set up with Mesa as well.
Jon
Jon
Time to create page: 0.092 seconds
